ASB.00.250.NTM
ASB.00.250.NTM
    LEMO(雷莫)
    SMA(DO-214AC)
    ASB.00.250.NTM
ASB.00.250.NTM 数据手册
ASB.00.250.NTM www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Coupler/adapter/bridge IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ASB*: Adapter from LEMO receptacle to SMA receptacle Keying Circular, female Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 5.73 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm Contact Retention: 18 N Contact Dia.: 0.7 mm (0.03in) Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Endurance (Shell): >1000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >144 hr DRAWINGS Dimensions A L mm. 9 30.8 in. 0,35 1,21 RECOMMENDED BY LEMO Tools Crimp Tool: DPC.91.701.V LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
ASB.00.250.NTM 价格&库存
很抱歉,暂时无法提供与“ASB.00.250.NTM”相匹配的价格&库存,您可以联系我们找货
