MS-145-HRMJ
MS-145-HRMJ
    HRS(广濑)
    CONN ADAPT MS-145 PLUG-SMA JACK
MS-145-HRMJ 数据手册
Interface Coaxial Switches MS-145 Series ■Overview and applications Designed primarily as interface coaxial switch for a mobile phones, they are also used in variety of other applications requiring redirecting of signals when mating with corresponding plug. The mating action redirects the signals from the receptacle side to the plug side. Receptacle ■Features 01. Frequency range Can be used from DC to 2.5 GHz and with GSM, PCS, cdmaOne,W-CDMA, etc. 02. Low profile Low protrusion of only 6mm above the mounting surface (receptacle). 03. Durability High durability(mating/unmating) of 10 000 cycles. 04. Self alignment of mating parts Inducement to floating is ±0.5mm. 05. Light weight Plug Weight is only 0.18g. 06. Small board surface solder area The area is 7 ∞4.6mm(excluding leads). 07. Automatic mounting Receptacle designed for placement on board with automated equipment. 08. Solder wicking Receptacle terminations are designed to prevent solder wicking into the critical contact areas. MS-145-C(LP)-1 MS-145-C(LP)-A MS-145-HRMJ MS-145-HRMP 09. Plugs Wide variety of mating heights are available. 10. Adaptors Different adaptors are available. ■Applications Mobile Phone antenna switching Checks of microwave boards, etc. ■Materials Part Material Outer shell Phosphor bronze Insulator Polyamide resin Common contact Beryllium copper Board circuit side (N.C.) contact Beryllium copper Color/Finish UL standard --------------- UL94HB Mounting area : Solder over Nickel plating --------------- Contact area : Gold over Nickel plating --------------- Others : Nickel Plating --------------- --------------- Gold plating Mounting area : Solder over Nickel plating --------------- Contact area : Gold over Nickel plating --------------- Others : Nickel Plating --------------- 113 ■Performance Specification Operating temperature range -30ç to +85ç Power 2 W (4W : at 1/8 duty ratio) Frequency range DC to 2.5 GHz 0.3 dB or less (DC to 1 GHz) Insertion loss 0.4 dB or less (1 GHz to 2 GHz) 0.6 dB or less (2 GHz to 2.5 GHz) 20 dB or greater (DC to 1 GHz) Isolation 15 dB or greater (1 GHz to 2 GHz) 12 dB or greater (2 GHz to 2.5 GHz) 1.3 or less (DC to 2 GHz) V.S.W.R. 1.5 or less (2 GHz to 2.5 GHz) Item Requirement Test Condition 1. Insulation resistance 1 Gø or more Measured at 100 V DC 2. Voltage proof No arcing or insulation breakdown 100 V AC applied for one minute 3. Contact resistance Center: 75 mø or less Outside: 50 mø or less Measured at 100 mA or less 4. Vibration No momentary disconnections of 10 µs or more Contact resistance Center: 100 mø or less Outside: 75 mø or less Frequency 10 to 50 Hz, amplitude 1.5 mm, at 2 h, for 3 directions No momentary disconnections of 10 µs or more Contact resistance Center: 100 mø or less Outside: 75 mø or less 490 m/s2, half-sine waveform, at 3 times for 3 directions Center: 100 mø or less Outside: 75 mø or less Insulation resistance 10 Mø or more Temperature : -55ç / 5 to 35ç / to 85ç / 5 to 35ç Time : -30 min / Within 5 min / 30 min / Within 5 min 100 cycles Center: 100 mø or less Outside: 75 mø or less No excessive corrosion Exposed in 5% salt water spray for 48 h, at 35ç 5. Shock Contact resistance 6. Thermal shock Contact resistance 7. Corrosion salt spray 8. Durability (Mating/Unmating) Contact resistance Center: 100 mø or less Outside: 75 mø or less ■Typical performance dB 40 N.O. 20 15 10 Isolation N.O. 0.6 0.4 0.2 0 1.60 Insertion loss N.C. N.O. 1.40 VSWR 1.20 N.C. 1.00 DC 114 1 Frequercy GHZ 2 2.5 10000 Mating/Unmating cycles ■Receptacle dimensions BCircuit configuration Parts No : MS-145(06) Package condition (1,000 pieces per reel) All dimensions in mm. Not mated with plug (Normally closed) Mated with plug (Normally open) 6 4 5.4 G G A G G A B G C G B G C G B Ø5.06 Ø3 Plug MS-145 BRecommended solder board 3.65 6 2-0.2 2-0.15 mounting pattern 7 2.4 0.9 1 A G G 6.4 C R2 2- 4.6 2.3 0.5 1.4 BTape and reel dimensions (1,000 pieces per reel) 12 4 2 Ø1.5 Unwinding direction 1.75 2 16.4 7.5 16 Ø380 Ø80 Unwinding direction 7.5 Ø13: Center Opening 115 ■Plug MS-145-C(LP)-1 MS-145-C(LP)-A 7 MS-145-C(LP)-MI 7 7 13.7 13.7 13.7 10.2 10.2 10.2 Ø1.8 Ø1.8 Ø1.8 1.7 Ø5.55 14.2 Ø5.55 15.5 13.15 15.5 4.65 5.95 Ø4.15 Ø4.15 Ø5.55 8.2 Ø4.15 ■MS-145 to SMA adaptor MS-145 to SMA Male MS-145 to SMA Female Straight type Panel mount type Straight type MS-145-HRMP-A MS-145-HRMJ MS-145-HRMJ-A-D 12.7 8.64 8HEX 6.3 8.64 12.7 1/4-36UNS-2B 4-Ø 2.6 Ø7.3 1/4-36UNS-2A 1/4-36UNS-2A 6 19.87 14.03 18 5.3 11.37 7 23.13 6.7 1.7 Ø4.3 Ø4.9 7.4 Ø4.15 Ø4.15 116 BUsage precautions 1. Please select plugs according to the following applications. Part No. MS-145-C(LP)-1 Engagement position Engages up to a position (Q point) of 1.3 mm from the 5.06 mm diameter shoulder of the MS-145 Effective engagement length (Nominal) 0.82mm MS-145-C(LP)-A MS-145-C(LP)-MI Engages by pushing up to the 5.06 mm diameter shoulder (P surface) MS-145-HRMJ-A-D of the MS-145 1.32mm MS-145-HRMP-A MS-145-HRMJ Engages by pushing up to the 5.06 mm diameter shoulder (P surface) of the MS-145 0.82mm Ø5.06 "Q"point "P" urface 3.65 1.3 2. Applicable cable for plugs: 1.5D-HQEW or 1.5D-QEW (manufactured by Fujikura Ltd.). 3. No cleaning is needed after soldering or cable termination. 4. Please design avoiding holes so that force is not applied to this product from the case when dropped in the board mounted condition. 5. When mounted as the RF interface of a Mobile Phone, please consider using a rubber cap when the plug is not engaged to prevent dust from entering. 117 BApplication examples receptacle Plug O-ring Cable 17 BRecommended solder temperature profile BRecommended nozzle configuration (For receptacle board placement with automatic equipment) Ø1 Ø1.5 Ø3 118
MS-145-HRMJ 价格&库存
很抱歉,暂时无法提供与“MS-145-HRMJ”相匹配的价格&库存,您可以联系我们找货
