GT5-2S-HU(35)
GT5-2S-HU(35)
    HRS(广濑)
    CONN PCB HOUSING 2POS
GT5-2S-HU(35) 数据手册
GT5 For Antenna Patented GT13 In-vehicle shielding connector with twin crimp technology GT16 GT36 GT11 GT17 GT32 GT3 GT25 GT8E In-car communication, car sensors (temperature, pressure), automotive audio systems, GPS antenna systems, RACS antenna audio/video antenna systems, CRT displays, medical and measuring instrumentation, variety of communication equipment, office automation equipment, LAN systems. GT18W Applications GT10 USCAR specified connector as SAE/USCAR-19 Low cost cable assembly Highly efficient and reliable one step crimp termination "Twin Crimp TM " allows high volume production with semi-automatic equipment. Space-saving design Excellent high frequency performance Refer to V.S.W.R. data on the following pages. GT7 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT26 Features GT9 GT15 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 7 For Antenna GT21 GT19 ---- Connectors for coaxial cables ---- PO5G GT5 Series B Test Data (Using 1.5D-2V Type cable) GT16 GT13 GT5 GT5 Series ● For Antenna High Frequency Characteristics (V.S.W.R.) 3.0 PO5G 2.6 GT19 2.4 2.2 GT21 2.0 1.8 GT26 1.6 1.4 GT36 1.2 1 1.0 2.0 3.0GHZ B Termination sequence 3. Insert the terminal in the housing until fully locked. Push in the terminal with cable in the housing until the housing lance locked. 1. Strip the cable 3.5 9.5 5 GT9 GT8E GT25 GT18W GT10 GT7 GT3 GT32 GT17 GT11 Note : Typical data using fully assemblied and connected GT5-1S-HU and the GT5-1PP-HU. GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.8 8 2. Crimp the cable to the terminal. 4. Fully insert the retainer. Push in the retainer until locked. GT5 Series ● For Antenna GT5 A GT16 4.6 F Connector Terminals GT13 5.8 4.6 Terminals for coaxial cable * * * Ø2.0 to 2.5 Ø3.3 to 3.7 Ø3.6 to 4.0 30 AWG 24 to 28 AWG 20 to 22 AWG 30 AWG 24 to 28 AWG 20 to 22 AWG Ø2.5 to 2.9 RoHS 1,300 pcs/reel YES 22.7 1,100 pcs/reel Ø4.6 to 5.0 Ø3.0 to 3.6 GT36 Note : Products marked with an asterisk (*) indicate polyethylene foam insulation. A 5.8 Terminals for M Connector  GT11 5.8 GT17 GT32 Part No. * * 20 to 22 AWG Ø2.0 to 2.5 Ø3.3 to 3.7 Ø3.6 to 4.0 30 AWG 24 to 28 AWG 20 to 22 AWG 30 AWG 24 to 28 AWG 20 to 22 AWG Ø2.5 to 2.9 900 pcs/reel YES Packaging RoHS 900 pcs/reel YES 24.05 Ø4.6 to 5.0 Ø3.0 to 3.6 GT18W * Ø1.5 to 2.0 Ø2.6 to 3.4 23.05 RoHS Note : Products marked with an asterisk (*) indicate polyethylene foam insulation. A Terminals for Low-insertion M Connector GT25 5.8 * 24 to 28 AWG Packaging GT10 * 755-0017-9 70 755-0021-6 70 755-0001-9 70 755-0094-0 70 755-0076-8 70 Insulator:PBT/Dark Gray 755-0053-2 70 Center terminal:Brass/Tin plating 755-0015-3 70 Outer terminal:Brass/Tin plating 755-0011-2 70 755-0033-5 70 755-0019-4 70 755-0023-1 70 755-0035-0 70 Insulation Conductor Size (AWG) Inner Diameter Outer Diameter A Ø0.6 to 0.9 Ø1.4 to 1.8 24.05 30 AWG GT8E 5.8 * Material/Plating or Color GT7 * GT5-30/0.7-1.5PCF(70) GT5-30/1.6-2.9PCF(70) GT5-2428/1.6-2.9PCF(70) GT5-2022/1.6-2.9PCF(70) GT5-2022/F2.7-3.5PCF(70) GT5-2022/F3.3-3.8PCF(70) GT5-30/F3.3-5PCF(70) GT5-2428/F3.3-5PCF(70) GT5-2022/F3.3-5PCF(70) GT5-30/F4-5PCF(70) GT5-2428/F4-5PCF(70) GT5-2022/F4-5PCF(70) HRS No. GT3 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. * 20 to 22 AWG Packaging GT26 * 755-0065-1 70 755-0123-6-70 755-0078-3 70 755-0022-9 70 755-0002-1 70 755-0071-4 70 Insulator:PBT/Dark Gray 755-0077-0 70 Center terminal:Phosphor bronze/ 755-0054-5 70 Tin plating 755-0016-6 70 Outer terminal:Brass/Tin plating 755-0012-5 70 755-0034-8 70 755-0020-3 70 755-0024-4 70 755-0036-3 70 Insulation Conductor Size (AWG) Inner Diameter Outer Diameter A Ø0.6 to 0.9 Ø1.4 to 1.8 22.7 30 AWG Ø1.0 to 1.4 Ø2.0 to 2.4 24 to 28 AWG Ø2.3 to 2.7 30 AWG 21.7 Ø1.5 to 2.0 Ø2.6 to 3.4 24 to 28 AWG GT21 * Material/Plating or Color GT19 * GT5-30/0.7-1.5SCF(70) GT5-2428/1.1-2.2SCF GT5-2428/1.6-2.5SCF(70) GT5-30/1.6-2.9SCF(70) GT5-2428/1.6-2.9SCF(70) GT5-2022/1.6-2.9SCF(70) GT5-2022/F2.7-3.5SCF(70) GT5-2022/F3.3-3.8SCF(70) GT5-30/F3.3-5SCF(70) GT5-2428/F3.3-5SCF(70) GT5-2022/F3.3-5SCF(70) GT5-30/F4-5SCF(70) GT5-2428/F4-5SCF(70) GT5-2022/F4-5SCF(70) HRS No. GT9 Part No. HRS No. Material/Plating or Color 755-0068-0 70 Insulator:PBT/Dark Gray 755-0079-6 70 Center terminal:Brass/Tin plating 755-0067-7 70 Outer terminal:Brass/Tin plating 755-0066-4 70 Insulation Conductor Size (AWG) Inner Diameter Outer Diameter A Ø0.6 to 0.9 Ø1.4 to 1.8 24.05 Ø2.3 to 2.7 Ø1.5 to 2.0 23.05 Ø2.6 to 3.4 30 AWG 24 to 28 AWG 30 AWG 24 to 28 AWG GT15 GT5L-30/0.7-1.5PCF(70) GT5L-2428/1.6-2.5PCF(70) GT5L-30/1.6-2.9PCF(70) GT5L-2428/1.6-2.9PCF(70) 9 For Antenna PO5G Part No. 9.6 1 Pos. for coaxial cable 25 PO5G 13 Housings 11.1 F Connectors GT19 GT21 GT26 GT36 Part No. GT5-1S-HU GT5-1S-HU(A) GT5-1S-HU(B) GT5-1S-HU(C) HRS No. 755-0004-7 755-0037-6 755-0038-9 755-0080-5 Material Color PBT Light Gray Brown Green Blue Key polarizing Corresponding M Connector code Housing- In-line Standard GT5-1PP-HU(70) GT5-1PP-HU(A)(70) (A) GT5-1PP-HU(B)(70) (B) GT5-1PP-HU(C)(70) (C) Corresponding M Connector Packaging RoHS Assembly- Board Mounting GT5-1P-DS(70) GT5-1P-DS(A)(70) YES 1 GT5-1P-DS(B)(70) GT5-1P-DS(C)(70) GT11 GT17 GT3 2.8 7.85 GT32 14.8 Part No. GT5-1P/S-R HRS No. Material Color 755-0006-2 PBT Dark Gray Packaging RoHS 1 YES GT10 GT7 (C) *Used with separate retainer (GT5-1P/S-R),  which is sold separately. 9.6 Housing (Retainer is not required) GT25 GT18W (B) GT5-1S-HU Retainer (Used with : GT5-1S-HU, GT5-1PP-HU, GT5N-1PP-HU, GT5H-1PP-HU) 13 Part No. GT5R-1S-HU 1.2 11.1 GT8E 25 GT5R-1S-HU GT9 (A) (26.35) *Mating Table(M Connectors) Prease use a matching key tipe. 10 Standard BShown with inserted retainer. ※ GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16 GT13 GT5 GT5 Series ● For Antenna HRS No. Material Color 755-0047-0 PBT Light Gray Packaging RoHS 1 YES GT5 Series ● For Antenna GT5 M Connectors 14.8 GT13 Housings (C) 13.4 (B) Mounting bracket attachment side BShown with inserted retainer. (31.35) Corresponding F Key polarizing Packaging RoHS Color Connector Housing Material/Plating code GT5-1S-HU Light Gray Standard Housing:PBT Brown GT5-1S-HU(A) (A) Ground terminal: 1 YES Phosphor bronze/ Green GT5-1S-HU(B) (B) Tin plating GT5-1S-HU(C) Blue (C) GT36 Note 1 : Refer to pages 27 for panel mounting in-line bracket. Note 2 : Please use a mating F connector housing of a matching key type. *Used with separate retainer (GT5-1P/S-R), which is sold separately. GT11 Housings (For use with H type mounting bracket) BMated condition 14.3 (41.4) 30 25 11.8 (11.4) 0.8 9.85 13.4 GT5-1S-HU (1.35) *Used with separate retainer (GT5-1P/S-R),  which is sold separately. GT5H-1PP-HU(10) 755-0093-7 10 PBT Corresponding F Connector Housing GT5-1S-HU Light Gray GT5R-1S-HU Color Packaging RoHS 1 YES GT7 Material GT3 HRS No. GT10 Housing (For use with N type mounting bracket) BMated condition (41.4) 0.6 GT5-1S-HU GT5-1P/S-R (1.35)(1.35) 3 9.2 Material 755-0090-9 PBT Packaging RoHS 1 YES GT15 Corresponding F Connector Housing GT5-1S-HU Light Gray GT5R-1S-HU Color GT9 GT5N-1PP-HU HRS No. GT8E Part No. *Used with separate retainer (GT5-1P/S-R),  which is sold separately. GT25 GT5-1P/S-R 17 6.8 (11.4) GT5N-1PP-HU 15.9 13.5 9.95 12.2 GT18W 30 30 25 GT32 GT5-1P/S-R GT5-1P/S-R (1.35) GT17 GT5H-1PP-HU Part No. GT26 HRS No. 755-0005-0 70 755-0039-1 70 755-0040-0 70 755-0103-9 70 GT21 Part No. GT5-1PP-HU(70) GT5-1PP-HU(A)(70) GT5-1PP-HU(B)(70) GT5-1PP-HU(C)(70) GT19 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ground terminal 11 For Antenna (A) PO5G Standard GT16 30 Housings mounting, [ Panel enhanced shielding type ] BRecommended Panel Cut-out GT16 GT13 GT5 GT5 Series ● For Antenna 19 10.4 15 11.6 M3 5.8 30 7 2-φ 3. 4 BMated condition (mounted) 13.4 Panel thickness (11.4) GT36 Note 2 Part No. HRS No. Material/Plating or Color GT5A-1PP-HU(70) 755-0025-7 70 Housing:PBT/Light Gray Ground terminal:Brass/Tin plating GT5-1P/S-R (1.35) Corresponding F Connector Packaging RoHS Housing GT5-1S-HU 1 YES GT5R-1S-HU Note 1 : Retainer is not required. Note 2 : Use JIS B 1111 and 1101 M3 screws for the mounting screws. GT17 GT11 GT5-1S-HU 15 GT26 6.2 GT21 14 11.15 11.8 26 12.4 9.95 PO5G GT19 19 30 13 11.8 M 3 11.6 4 15 GT7 9.5 9.5 φ 3. 5.8 GT3 12.4 9.95 GT32 BRecommended Panel Cut-out 30 GT18W GT10 6.2 13.4 7 14 11.15 4 GT25 GT8E GT9 GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4 12 Part No. HRS No. Material/Plating or Color GT5P-1PP-HU(70) 755-0030-7 70 Housing:PBT/Light Gray Ground terminal:Brass/Tin plating Note 1 : Retainer is not required. Note 2 : Use JIS B 1111 and 1101 M3 screws for the mounting screws. Corresponding F Connector Packaging RoHS Housing GT5-1S-HU 1 YES GT5R-1S-HU 10.4 GT5 Series ● For Antenna GT5 GT13 30 3.2 26 16.8 11.8 GT5-1S-HU 7 8.1 5 13.4 11.15 15.9 GT21 19 GT26 HRS No. Material/Plating or Color GT5B-1PP-HU(70) 755-0051-7 70 Housing:PBT/Light Gray Ground terminal:Phosphor bronze/Tin plating Corresponding F Connector Packaging RoHS Housing GT5-1S-HU 1 YES GT5R-1S-HU GT11 Part No. GT36 Note 1 : Retainer is not required. Note 2 : Use JIS B 1115 and 1122 class 4, nominal diameter 3, length 6 screws for the mounting screws. GT17 11.8 12.8 26 12.65 30 GT32 27.4 12.3 GT5-1S-HU GT5-1P/S-R 11.15 7 8.1 19 GT18W 4 3.2 GT10 13.4 14 2.6 GT7 Chassis Assembly Diagram 3.6 GT3 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 5 1.2 GT25 Material/Plating or Color GT5S-1PP-HU(70) 755-0050-4 70 Housing:PBT/Light Gray Ground terminal:Phosphor bronze/Tin plating Corresponding F Connector Packaging RoHS Housing GT5-1S-HU 1 YES GT5R-1S-HU Note 1 : Retainer is not required. Note 2 : Use JIS B 1115 and 1122 class 4, nominal diameter 3, length 6 screws for the mounting screws. GT9 HRS No. GT8E Part No. GT15 13 For Antenna Chassis Assembly Diagram 1.2 PO5G GT5-1P/S-R 2.6 GT16 12.65 27.4 12.3 Board Mounting Type 12.8 11.8 11.8 2.5 11.8 11.8 3 3 4 13.9 12.8 (B) GT19 13.9 (A) 12.8 4 PO5G Standard (C) BMated condition GT21 (32.7) 21.3 BRecommended PCB    Mounting Pattern (11.4) GT5-1S-HU GT5-1P-DS (70) 5.45 (1.35) HRS No. GT5-1P-DS(70) GT5-1P-DS(A)(70) GT5-1P-DS(B)(70) GT5-1P-DS(C)(70) 755-0007-5 70 755-0041-3 70 755-0042-6 70 755-0083-3 70 Key polarizing code Housing:PBT/ー Light Gray Standard Center terminal:Brass/Tin plating Brown (A) Insulator:PBT/Dark Gray Green (B) Outer terminal:Phosphor bronze/Tin plating Blue (C) Material/Plating or Color Color 5.25 15.4 For center terminal φ1.2 GT5-1P/S-R 7.7 For outer terminal 2-φ1.2 Note Part No. 3.2 3 Panel Corresponding F Connector Housing Packaging RoHS GT5-1S-HU GT5-1S-HU(A) 1 YES GT5-1S-HU(B) GT5-1S-HU(C) Note 1 : Use JIS B 1115 and 1122 class 4, nominal diameter 3, length 6 screws (for a board thickness of 1.6 mm) for the mounting screws. Note 2 : Please use a mating F connector housing of a matching key type. GT32 GT17 GT11 GT36 T=1.6 GT26 2-φ GT3 21.3 BMated condition 15.1 11.8 15.4 (32.7) GT5E-1P-DS(71) GT5-1S-HU 11 GT5-1P/S-R 0.5 3.5 13.4 7.05 (1.35) 5.25 13.67 Material/Plating or Color 755-0125-1 71 Housing:PA/Natural Center terminal:Brass/Tin plating Insulator:PA/Black Outer terminal:Phosphor bronze/Tin plating Fixing pin:Brass/Tin plating GT9 HRS No. Corresponding F Connector Housing Packaging RoHS GT5-1S-HU 1 GT5R-1S-HU YES For center terminal Ø1.2 For fixing pin Ø1.3 7.05 11 13.67 GT8E For outer terminal 2ר1.2 5.25 GT25 BRecommended PCB  Mounting Pattern GT5EC-1P-DS(71) 14 (11.4) 21.3 T=1.6 GT7 GT10 GT18W 3 Part No. GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16 20.4 15.4 3 3 φ 4 13.9 13.9 21.3 GT13 GT5 GT5 Series ● For Antenna 3 Panel GT5 Series ● For Antenna GT5 1 Pos. for coaxial cable 2 coaxial type 16.6 GT13 F Connectors Housing (B) 1.2 (1.35) GT19 GT21 GT5-2P/S-R BShown with inserted retainer. Material Color 755-0044-1 755-0059-9 755-0060-8 755-0097-8 PBT Light Gray Brown Green Blue Key polarizing Packaging RoHS code Standard (A) 1 YES (B) (C) GT36 GT5-2S-HU GT5-2S-HU(A) GT5-2S-HU(B) GT5-2S-HU(C) HRS No. GT26 Part No. Note 1 : Assemble main parts with separate retainer (GT5-2P/S-R). Note 2 : Please use a mating F connector housing of a matching key type. GT11 M Connectors BRecommended Mounting Bracket dimensions. 0.6 1 2.6 1.52 17.75 1.6 4.2 7.8 9.8 6.8 1.3 5 14.5 21.8 8 41.4 GT5-2S-HU GT5-2P/S-R GT5-2P/S-R GT5-2PP-HU(70) GT5-2PP-HU(A)(70) GT5-2PP-HU(B)(70) GT5-2PP-HU(C)(70) 755-0045-4 70 755-0063-6 70 755-0064-9 70 755-0099-3 70 Housing:PBT Ground terminal:Phosphor bronze /Tin plating Note 1 : Assemble main parts with separate retainer (GT5-2P/S-R). Note 2 : Please use a mating F connector housing of a matching key type. Key polarizing Packaging RoHS code Light Gray Standard Brown (A) 1 YES Green (B) Blue (C) Color GT15 Material/Plating (C) GT9 HRS No. (B) GT8E Part No. (A) (1.35) GT25 (1.35) GT18W 1.2 (11.4) GT10 BMated condition Standard GT7 Tin plating 30 25 GT3 1.5 GT32 4.75min 5 2.8 GT17 Housings[Panel Mounted Housing] 15 For Antenna 25 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (C) PO5G 13.3 0.4 11.5 (A) GT16 Standard 25 GT5 GT5 Series ● For Antenna Housings GT13 BMated condition 41.4 (11.4) PO5G GT19 GT21 GT5-2P/S-R GT5-2P/S-R 13.8 16.2 GT16 30 25 (1.35) Part No. GT5N-2PP-HU HRS No. Material Color 755-0055-8 PBT Light Gray (1.35) Packaging RoHS YES 1 Note : Assemble main parts with separated retainer (GT5-2P/S-R). GT26 Retainer (Used with GT5-2S-HU, GT5-2PP-HU, and GT5N-2PP-HU) GT11 2.8 GT36 10.9 14.8 GT5-2P/S-R HRS No. Material Color 755-0046-7 PBT Dark Gray Packaging RoHS YES 1 Board Mounting Type 2.5 3 3 0. 20.2 19.2 8.2 11.8 5 3.2 .3 Board d 1.5 14.05 0.3 2-R 5 3.2 5 3.6 R 7 R2 Board 2- 22.4 3. 25 14.05 14 05 0.3 20.2 20 2 19.2 7 2-R 3.2 2-R 3.6 8.2 0. R R 22.4 2- 7 19.2 14.05 0.3 20.2 19.2 GT18W 14.05 0.3 0. R 2- 7 0. R 2- GT25 (11.4) GT5-2S-HU GT5-2P/S-R 22.4 GT10 For outside conductor 4-φ1.2 3 5.45 GT8E (32.7) 21.3 12.6 T-1.6 21.3 Board GT9 BMated condition (mounted) 22.4 5.45 (C) (B) 5.25 7.7 Panel 2-φ 3.5 For inner conductor 2-φ1.2 27.4 16 (A) BRecommended Board Mounting Pattern 4 14.15 GT7 7 7.7 3 Standard 18.8 5.25 7.7 GT3 22.4 3 GT32 2-φ 22.4 GT17 Part No. GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT5-2S-HU 18.8 GT5-2P-DS (70) GT5-2P-DS (A)(70) GT5-2P-DS (B)(70) GT5-2P-DS (C)(70) Recommended Panel Cut-out Part No. HRS No. GT5-2P-DS(70) 755-0043-9 70 GT5-2P-DS(A)(70) 755-0061-0 70 GT5-2P-DS(B)(70) 755-0062-3 70 GT5-2P-DS(C)(70) 755-0101-3 70 Material/Plating or Color Housing:PBT/ー Center terminal:Brass/Tin plating Insulator:PBT/Dark Gray Outer terminal:Phosphor bronze/Tin plating Note 1 : Housing. Note 2 : Use JIS B 1115 and 1122 class 4, nominal diameter 3, length 6 screws. Key polarizing Packaging RoHS code Light Gray Standard Brown (A) 1 YES Green (B) Blue (C) Color GT5 Series ● For Antenna GT5 Terminals for Power Supply GT13 Terminals for F Connector 2.8 GT16 2.3 19 GT21 GT26 Material Plating Tin plating Conductor Size (AWG) 20 to 22 AWG Outer Diameter Ø1.4 to 2.4 Ø2.6 to 3.1 Packaging RoHS 5,000 pcs/reel 3,000 pcs/reel YES Note 1 : Sold in reel. (See above table for number of Packaging.) Note 2 : This component is used only with applicable HRS housings. GT11 Copper alloy GT36 GT17 Terminals for M Connector GT32 2.8 1.9 2.7 GT3 GT7 GT10 20.7 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 HRS No. GT18W GT25 GT8E Part No. HRS No. Brass Plating Tin plating Conductor Size (AWG) 20 to 22 AWG Outer Diameter Ø1.4 to 2.4 Ø2.6 to 3.1 Packaging RoHS 5,000 pcs/reel 3,000 pcs/reel YES GT9 GT7-2022PCF(70) 757-0002-4 70 GT7A-2022PCF(70) 757-0004-0 70 Material Note 1 : Sold in reel. (See above table for number of Packaging.) Note 2 : This component is used only with applicable HRS housings. GT15 17 For Antenna PO5G Part No. GT7-2022SCF(70) 757-0001-1 70 GT7A-2022SCF(70) 757-0003-7 70 GT13 GT5 GT5 Series ● For Antenna Combinaton Type (2 Coaxials + 1 Power contact) F Connectors 21.1 BShown with inserted retainer. PO5G (26.35) 10.8 GT19 12.5 25 ※ (GT5-2/1S-R) Part No. HRS No. Material Color GT5-2/1S-HU 755-0009-0 PBT Light Gray Packaging RoHS 1 YES Retainer (Only for GT5-2/1S-HU) 17.28 HRS No. Material Color 755-0003-4 PBT Dark Gray Packaging RoHS 1 YES M Connectors BRecommended Board Mounting Pattern GT25 GT5-2/1P-DS(70) HRS No. Material/Plating or Color 755-0014-0 70 Housing:PBT/Light Gray Center terminal:Brass/Tin plating Insulator:PBT/Dark Gray Outer terminal:Phosphor bronze/Tin plating For power supply terminal:Brass/Tin plating Packaging RoHS 23.7 GT8E Part No. 5 .2 R3 GT9 5.25 3 5.45 BRecommended Panel Cut-out 4- 18 7 13.1 26.9 For inner terminal 2×φ1.2 For outside terminal 4×φ1.2 23.3 13.4 GT18W 21.3 7.7 GT10 31.9 26.9 Panel For power 2 supply terminal ר3 .5 φ1.4 5.25 Part No. GT5-2/1S-R 1 Note : Use JIS B 1115 and 1122 class 4, nominal diameter 3, length 6 screws (for a board thickness of 1.6 mm) for the mounting screws. 13.3 0.3(distance between PCB and panel opening) 26.9 GT7 GT3 GT32 2.8 GT17 16.6 GT11 GT36 GT26 GT21 *Used with separate retainer (GT51P/S-R), which is sold separately. Board mounting type GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16 Housing YES Board GT5 Series ● For Antenna GT5 M Connectors BShown with inserted retainer. (31.35) GT13 Housing GT16 *Used with separate retainer (GT51P/S-R), which is sold separately. 2.8 1 1.52 2.6 5 0.6 13.4 17.75 4.75min GT19 Mounting bracket attachment side Material/Plating or Color HRS No. 1 Tin plating YES 1.3 14.5 8 GT36 5 Note : Refer to pages 27 for panel Mounting In-line Bracket. 9.8 4.2 Packaging RoHS Housing:PBT/Light Gray GT5-2/1PP-HU(70) 755-0008-8 70 Ground terminal:Phosphor bronze/Tin plating GT26 Part No. 7.8 1.6 1.5 6.8 Ground terminal GT21 GT11 GT17 23.3 13.4 15.8 30 25 HRS No. Material Color 755-0013-8 PBT Light Gray GT3 Part No. GT5N-2/1PP-HU Packaging RoHS 1 GT32 YES GT7 Note : Assemble main parts with separated retainer. (GT5-2/1PP-R) GT18W 16.6 15.36 GT10 Retainer (Used with GT5N-2/1PP-HU and GT5-2/1PP-HU) GT25 3.5 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BRecommended Mounting Bracket    Dimensions GT8E HRS No. Material Color 755-0010-0 PBT Dark Gray Packaging RoHS 1 GT9 Part No. GT5-2/1PP-R YES GT15 19 For Antenna 26.3 PO5G 30 31.9 33.6 F Connectors GT5-4P/S-R GT21 GT19 1 0.4 PO5G 13.3 11.5 25 Part No. GT5-4S-HU HRS No. Material Color 755-0056-0 PBT Light Gray Packaging RoHS 1 YES M Connectors GT36 GT26 Note : Assemble main parts with separated retainer GT5-4P/S-R. 30 21.5 14.6 3 9.2 8.5 31.9 GT32 GT3 GT7 13.8 16.2 GT17 0.6 1.2 GT11 35.8 31.9 Part No. GT5N-4PP-HU HRS No. Material Color 755-0057-3 PBT Light Gray Packaging RoHS 1 YES Note 1 : The product should be used with a low-force insertion/withdrawal M connector terminal. Note 2 : Assemble main parts with separated retainer GT5-4P/S-R. Retainer (Only for GT5-4S-HU and GT5N-4PP-HU) GT9 GT8E 2.8 GT25 GT18W 27.6 GT10 14.8 Part No. GT5-4P/S-R GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BShown with inserted retainer. 1 Pos. for coaxial cable 4 coaxials type GT16 GT13 GT5 GT5 Series ● For Antenna 20 HRS No. Material Color 755-0058-6 PBT Dark Gray Packaging RoHS 1 YES GT5 Series ● For Antenna GT5 M Connectors GT13 Board Mounting type GT16 RoHS 755-0087-4 70 1 YES BRecommended Board Mounting Pattern 35.8 40.8 24 10 40.8 21.3 15.1 PIN No 3 GT17 For outer terminal 8-φ1.2 4 0.5 10.6 3 GT32 14.3 Panel 5.25 GT11 For inner terminal 4-φ1.2 3 .5 45.8 5.25 2-φ3 Lot No. 12.6 2.5 φ GT36 5.45 GT26 10 24 GT3 GT7 BRecommended Panel Cut-out 14.2 R0 (32.7) 21.3 0.3(distance between PCB and panel opening) .5 (11.4) 40.8 36.2 R3 GT5−4P/S−R Board GT8E 2- GT25 GT5−4S−HU GT18W 2- GT10 BMated condition (mounted) T−1.6 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Packaging Housing:PBT/Light Gray Center terminal:Brass/Tin plating Insulator:PBT/Dark Gray Outer terminal:Phosphor bronze/Tin plating GT21 Material/Plating or Color GT19 GT5-4P-DS(70) HRS No. M3 Screw Panel GT9 Board GT15 21 For Antenna PO5G Part No. GT13 GT5 GT5 Series ● For Antenna 1Pos. for coaxial cable with Waterproof type F Connectors Housing 16.45 PO5G 18.45 GT19 GT21 GT26 Part No. HRS No. Material Color GT5W-1S-HU 755-0027-2 PBT Light Gray Packaging RoHS 1 YES Retainer (Used with GT5W-1PP-HU, GT5JW-1PP-HU, GT5W-1S-HU and GT5W-1P-HU) GT32 GT17 GT11 GT36 Note : Use correct retainer. 15.4 15.9 GT3 8.7 GT7 GT10 Part No. GT9 GT8E GT25 GT18W GT5W-1P/S-R GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16 36 22 HRS No. Material/Plating or Color 755-0028-5 Retainer:PBT/Dark Gray Rubber:Silicon rubber Compound/Light Blue Packaging RoHS 1 YES Note : Outer diameter of the cable must be within Ø2.9 to Ø3.4 mm. *Waterproofness will depend on the cable. Please contact a Hirose Electric sales representative for further infomation when using this product GT5 Series ● For Antenna GT5 M Connectors 34 GT13 GT16 18.4 Housing 18.2 Packaging RoHS Housing:PBT/Light Gray 755-0026-0 Connector seal:Silicon rubber Compound/White 1 YES GT26 Note : Use correct retainer. 18.4 GT36 GT17 20.6 GT11 34 GT32 GT3 BRecommended Bracket Dimensions Diagram (Used with GT5W-1PP-HU) BMated condition (mounted) 0.6 1 0 9.8 -0.1 GT18W 7.8 GT10 1.52 +0.03 0 Please check elsewhere for information about the bracket for GT5JW-1PP-HU. (55.9) (35.75) GT25 4.2 1.5 6.8 GT7 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT21 Material/Plating or Color GT19 GT5W-1P-HU HRS No. 0 1.3 -0.1 GT8E 5 10 HRS No. Material/Plating or Color Housing:PBT/Light Gray 755-0070-1 755-0069-2 Connector seal:Silicon rubber Compound/White Packaging RoHS 1 YES GT9 Part No. GT5W-1PP-HU GT5JW-1PP-HU 8 Note : Use correct retainer. GT15 23 For Antenna PO5G Part No. G Terminals 1.9 Ø0.5 1.5D-2V or equivalent 9.3 2.3 39 2.9 0.4 3 3.5 0.6 1.2 GT21 2.3 2 BBoard Termination Pattern 0.6 1.2 2.9 (2.6) 7 2 3.9 6.9 GT19 1.5 (1.7) R 1 PO5G 6.3 2.5 6.4 14.6 10.8 1 6.4 Lands .6 φ 1. 2 Part No. HRS No. Material Plating Packaging RoHS 755-0032-2 70 Brass Tin plating 1,500 pcs/reel YES GT36 GTA-1.6CF(70) 1.9 BCompleted Termination cross section 8.1 12.6 (0.5) 9.85 8.3 7.6 GT11 GT17 (4) (1.6) (6.2) 7.775 GT32 1.35 1.5D-2Vor equivalent 3.5 8.8 (0.4) Heat-shrink tubing (3.5) 3.5 BBoard Termination Pattern 3.5 6 GT3 6.45 0.4 3 Ø1. La .2( nd Ø1.2(Lands) Ø0 .6 Material Plating Packaging RoHS Brass Tin plating 1,500 pcs/reel YES 14.6 10.8 0.5 BCompleted Termination cross section 1.9 R 2 (2.6) 7 0.4 3.2 3.3 6.5 GT25 1 9.3 1.5 GT8E 1.5D-2V or equivalent 2.5 6.3 GT18W Ø0.5 2 3.5 BBoard Termination Pattern (2.9) 1 GT15 GT9 (2.3) (1.2) GT10 HRS No. 755-0049-5 70 0.6 GT7 s) Part No. GTB-1.6CF(70) 24 8.25 GT26 φ0 Ø2 Lands 6.4 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BRecommended Completed    Termination cross section For Direct Coaxial Shielded Cable Termination GT16 GT13 GT5 GT5 Series ● For Antenna Ø0.6 .2 Ø1 Part No. GTC-1.6CF HRS No. Material Plating Packaging RoHS 755-0106-7 Brass Tin plating 1,500 pcs/reel YES 1.9 GT5 Series ● For Antenna 1.9 GT5 BCompleted Termination cross section φ0.5 6.3 3 R1 2.5 Heat-shrink tubing HRS No. Material Plating Packaging RoHS 755-0029-8 70 Brass Tin plating 1,500 pcs/reel YES 6.4 φ 1.2 Part No. GT19 1.9 BCompleted Termination cross section 9 0.5 2 14.3 5.7 7 0.6 1.2 2.9 2.3 0.25 5.25 (2.55) 3 0.8 BRecommended Board Termination Pattern Material Plating Packaging RoHS Brass Tin plating 1,500 pcs/reel YES 6.4 BRecommended Completed Termination cross section φ0.3 1.9 (0.5) 13.6 Pre-solder 8.55 R1 0.25 0.7 3.5 BRecommended Board Termination Pattern 2.6 Plating Packaging RoHS 755-0075-5 Brass Tin plating 1,500 pcs/reel YES .9 φ0 Lands BRecommended Completed Termination cross section 21.3 14.8 BRecommended Board Termination Pattern 2.9 2.3 63 0.5 3 6.3 0.7 1.3 5.5 GT9 1 2 0.7 1.3 9.9 2.5 8 13.3 GT8E 2 ands RG-71/UM or equivalent 7.3 GT25 3 φ0.33 2.9 2.3 2.95 Material GT18W GTB-0.7CF HRS No. GT10 1.9 2.4 1.8 φ 0.5 Part No. 0.7Dor equivalent GT7 4.75 2.4 2.5 7.4 0.5 1.1 1.5 0.8 0.5 GT3 2.8 0.15 0.25 GT32 9.8 1.9 GT17 HRS No. 755-0074-2 GT11 Lands φ0 .5 .2 φ1 3.3 29 Part No. 0.7Dor equivalent 3.5 GT36 1 GTA-0.7CF 2.8 GT26 0.25 R1 2.5 Pre-solder 10.5 6.15 0.25 1.9 (0.5) φ0.3 GT21 GTE-3.7CF HRS No. Material Plating Packaging RoHS 755-0122-3 Brass Tin plating 1,100 pcs/reel YES .5 φ0 1 φ 3 7 GT15 Part No. 5.6 9.9 Lands φ 1.1 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. .6 φ0 25 For Antenna Lands 0.4 G-1.6PCF(70) PO5G 2.9 2.3 0.6 1.2 1 10.6 7 BRecommended Board Termination Pattern GT16 2 (2.6)2 3.5 7 GT13 1.5D-2V or equivalent 6.9 Bottom Shield cover 5.4 GT13 GT5 GT5 Series ● For Antenna 2.63 PO5G 3.3 Assembled Part No. HRS No. GT5-1P/S-CSB(70) 755-0048-2 70 Material Plating Brass Tin plating Packaging RoHS 1 YES GT32 6.45 GT17 GT11 R1. 6 GT36 GT26 GT21 GT19 5.6 GT3 5.6 Assembled Part No. HRS No. GT9 GT8E GT25 GT18W GT10 GT7 GT5C-1P-CSB(70) 755-0088-7 70 GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16 5 26 Material Plating Brass Tin plating Packaging RoHS 1 YES T=0.25 GT5 Series ● For Antenna GT5 4.5 9.8 Panel Mounting In-line Bracket GT16 7.5 24.5 GT13 GT19 Part No. Material 751-0039-6 70 SPCC Plating Tin plating Used with connectors Packaging RoHS GT5-1PP-HU(B)(70) GT5-1PP-HU(D)(70) GT5-1PP-HU(F)(70) GT5-1PP-HU(H)(70) GT5-2PP-HU(70) GT5-2PP-HU(B)(70) 1 YES GT36 GT5-1PP-HU(70), GT5-1PP-HU(A)(70), GT5-1PP-HU(C)(70), GT5-1PP-HU(E)(70), GT5-1PP-HU(G)(70), GT5-2/1PP-HU(70), GT5-2PP-HU(A)(70), GT5-2PP-HU(C)(70) GT26 GT-BK(70) HRS No. GT21 B Crimping tools GT11 User's manuals are available. Please ask your Hirose Electric account representative. GT17 Automatic crimping machine Picture reference only GT32 Specifications Item Specification Press capacity 1.5tons Stroke length 30mm Number of strokes 200spm(50Hz) 75kg Motor 0.2kW Crimping speed GT18W * Crimp height setting tables are available for each cable type. Please contact your nearest Hirose Electric account representative. Different cables will require different crimp height settings. AC100V 2000 to 4000pcs/hour GT10 Part No. CM-105C 200spm(60Hz) GT7 Weight Remarks GT3 Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.1 GT25 GT8E GT9 GT15 27 For Antenna 12 8 PO5G T=1 Terminal HRS No. 755-0017-9 70 755-0065-1 70 755-0079-6 70 755-0078-3 70 GT5-30/1.6-2.9PCF(70) 755-0021-6 70 GT5-30/1.6-2.9SCF(70) 755-0022-9 70 GT5-2428/1.6-2.9PCF(70) 755-0001-9 70 GT19 GT5-2428/1.6-2.9SCF(70) 755-0002-1 70 GT21 GT5-2022/1.6-2.9SCF(70) GT5-2022/F2.7-3.5PCF(70) GT5-2022/F2.7-3.5SCF(70) GT5-2022/F3.3-3.8PCF(70) GT5-2022/F3.3-3.8SCF(70) 755-0071-4 70 755-0076-8 70 755-0077-0 70 755-0053-2 70 755-0054-5 70 GT5-2022/F3.3-5PCF(70) 755-0033-5 70 GT5-2022/F3.3-5SCF(70) 755-0034-8 70 GT36 GT5-30/F4-5PCF(70) GT5-30/F4-5SCF(70) 755-0019-4 70 755-0020-3 70 GT5-2428/F4-5PCF(70) 755-0023-1 70 GT11 GT5-2428/F4-5SCF(70) 755-0024-4 70 GT5-2022/F4-5PCF(70) 755-0035-0 70 GT5-2022/F4-5SCF(70) 755-0036-3 70 G-1.6PCF(70) GTA-0.7CF GTB-0.7CF GTA-1.6CF(70) GTB-1.6CF(70) GTC-1.6CF GTE-3.7CF 755-0029-8 70 755-0074-2 755-0075-5 755-0032-2 70 755-0049-5 70 755-0106-7 755-0122-3 GT9 GT8E GT25 GT18W GT10 GT7 GT3 GT32 GT26 PO5G GT16 Terminal Product No. GT5-30/0.7-1.5PCF(70) GT5-30/0.7-1.5SCF(70) GT5L-2428/1.6-2.5PCF(70) GT5-2428/1.6-2.5SCF(70) GT15 For Antenna Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Powered by TCPDF (www.tcpdf.org) Harness tools GT17 GT13 GT5 GT5 Series ● For Antenna 28 Tool No. AP105-GT5-30/0.7-1.5P AP105-GT5-30/0.7-1.5S AP105-GT5-2428/1.6-2.5P AP105-GT5-2428/1.6-2.5S AP105-GT5-30/1.6-2.9P-ID AP105-GT5-30/1.6-2.9P AP105-GT5-30/1.6-2.9S-ID AP105-GT5-30/1.6-2.9S AP105-GT5-2428/1.6-2.9P AP105-GT5-2428/1.6-2.9PWS AP105-GT5-2428/1.6-2.9P-B AP105-GT5-2428/1.6-2.9S AP105-GT5-2428/1.6-2.9SWS AP105-GT5-2428/1.6-2.9S-B AP105-GT5-2022/1.6-2.9S AP105-GT5-2022/F2.7-3.5P AP105-GT5-2022/F2.7-3.5S AP105-GT5-2022/F3.3-3.8P AP105-GT5-2022/F3.3-3.8S AP105-GT5-2022/F3.3-5P-ID AP105-GT5-2022/F3.3-5P AP105-GT5-2022/F3.3-5S-ID AP105-GT5-2022/F3.3-5S AP105-GT5-30/F4-5P-ID AP105-GT5-30/F4-5S-ID AP105-GT5-2428/F4-5P-ID AP105-GT5-2428/F4-5P-3C2V AP105-GT5-2428/F4-5S-ID AP105-GT5-2428/F4-5S-3C2V AP105-GT5-2022/F4-5P AP105-GT5-2022/F4-5P-18ID AP105-GT5-2022/F4-5S AP105-GT5-2022/F4-5S-18ID AP105-G-1.6P AP105-GTA.B-0.7P AP105-GTA.B-0.7P AP105-GTA.B-1.6P AP105-GTA.B-1.6P AP105-GTA.B-1.6P AP105-GTE-3.7 Tool HRS No. 901-5021-8 901-5080-7 901-5100-2 901-5101-5 901-5019-6 901-5017-0 901-5020-5 901-5018-3 901-5029-0 901-5031-1 901-5103-0 901-5030-9 901-5032-4 901-5104-3 901-5088-9 901-5091-3 901-5092-6 901-5075-7 901-5076-0 901-5058-8 901-5059-0 901-5060-0 901-5061-2 901-5033-7 901-5034-0 901-5035-2 901-5056-2 901-5036-5 901-5057-5 901-5052-1 901-5121-2 901-5053-4 901-5102-8 901-5041-5 901-5141-0 901-5141-0 901-5047-1 901-5047-1 901-5047-1 901-5151-3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: GT5-1P/S-CSB GT5-1P-DS GT5-1P-DS(20) GT5-1P-DS(A)(02) GT5-1P-DS(A)(71) GT5-1P-DS(B) GT5-1PDS(B)(02) GT5-1P-DS(C) GT5-1P-DS(E) GT5-1PP-HU GT5-1PP-HU(24) GT5-1PP-HU(73) GT5-1PP-HU(A) GT51PP-HU(C) GT5-1PP-HU(E) GT5-1S-HU(20) GT5-2428/1.6S/CC-HT GT5-2P-DS(A) GT5-2P-DS(A)(71) GT5-2PDS(C) GT5-2PP-HU(A) GT5-2PP-HU(B) GT5-2PP-HU(C) GT5-2S-HU(A) GT5-2S-HU(B) GT5-4P-DS GT52022/1.6-2.9SCF GT5-2022/F2.7-3.5PCF GT5-2022/F2.7-3.5SCF GT5-2022/F3.3-3.8PCF GT5-2022/F3.3-3.8SCF GT5-2022/F3.3-5PCF GT5-2022/F4-5PCF GT5-2022/F4-5SCF GT5-2428/1.6-2.9SCF GT5-2428/F3.3-5PCF GT52428/F3.3-5SCF GT5-2428/F4-5PCF GT5-2428/F4-5SCF GT5L-2428/1.6-2.9PCF GT5L-30/1.6-2.9PCF GT5E-1PDS GT5B-1PP-HU(60) GT5S-1PP-HU(10) GT5-2428/1.6-2.5SCF GT5L-30/0.7-1.5PCF GT5S-1PP-HU(60) GT5H1PP-HU(41) GT5T-1PP-HU GT5T-1PP-HU(10)
GT5-2S-HU(35) 价格&库存
很抱歉,暂时无法提供与“GT5-2S-HU(35)”相匹配的价格&库存,您可以联系我们找货
