Additional Resources:
Product Page
3D Model
date
09/26/2022
page 1 of 5
SERIES: SD | DESCRIPTION: STANDARD DIN CONNECTOR
FEATURES
• strain relief
• 3~13 pins
• 100 Vac rated
RoHS
PART NUMBER KEY
SD - XX
Base Number
Pin Options
30* = 3 pins
40* = 4 pins
50 = 5 pins, 180 degrees
60 = 6 pins
70 = 7 pins
80 = 8 pins, 270 degrees
81 = 8 pins, 262 degrees
130 = 13 pins
Note: *. Discontinued SD-30 & SD-40 models.
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
rated input current
typ
max
100
12
at 100 Vac
at 12 Vdc
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
Vac
Vdc
1
2
A
A
30
mΩ
100
MΩ
insertion force
1,000
Vac
4
kg
kg
withdrawal force
1
3.5
operating temperature
5
70
life
RoHS
5,000
yes
cuidevices.com
units
°C
cycles
Product Page
3D Model
CUI DEVICES | SERIES: SD | DESCRIPTION: STANDARD DIN CONNECTOR
date 09/26/2022 | page 2 of 5
MECHANICAL DRAWINGS
units: mm[inches]
tolerance: ±0.1 mm
2.0 0.079
15.8 0.622
MATERIAL
PLATING
contact pins (30~80)
brass
nickel
contact pins (81, 130)
brass
silver
shell
steel
nickel
insulator (30~80, 130)
PBT
insulator (81)
ABS
boot
EVA
50.6 1.992
0.2
9.0 0.354
1.5 0.059
(TYP)
6.5 0.256
0.15
0.7 0.028
13.1 0.516
0.15
45°
SD-30
SD-60
SD-40
SD-50
72°
90°
SD-70
SD-80
0.7
60°
45°
cuidevices.com
45°
Product Page
3D Model
date 09/26/2022 | page 3 of 5
units: mm[inches]
tolerance: ±0.1 mm
SD-81
2.00 0.079
1.5 0.059
(8 PLCS)
6.5 0.256
0.3
59.0 2.323
1.0
8.3 0.327
16.0 0.630
0.3
41°
0.9 0.035
13.2 0.520
45°
SD-130
15.9 0.63
13.2 0.52
0.78 0.03
0.02
(13 PLCS)
8.8 0.35
50.1 1.97
9.2 0.36
2.5 0.10
7.5 0.30
2.5 0.10
2.5 0.10
4.5 0.18
cuidevices.com
Product Page
3D Model
date 09/26/2022 | page 4 of 5
MECHANICAL ASSEMBLY
cover
1
1
2
metal shield
2
PIN DETAILS
3
housing
3
Note: SD-130 has solid solder pins. All
other models have solder cups.
2
STEP 1
solder wires to
housing (3),
assemble metal
shield pieces (2)
onto housing (3)
STEP 2
slide cover (1)
over metal shield (2)
2
3
2
2
cuidevices.com
1
Product Page
3D Model
date 09/26/2022 | page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/15/2012
1.02
updated housings
04/12/2012
1.03
corrected center pin positioning on SD-80
09/13/2013
1.04
updated datasheet
05/22/2017
1.05
updated datasheet
10/16/2018
1.06
brand update
02/19/2020
1.07
logo, datasheet style update
08/05/2022
discontinued models SD-30 & SD-40
09/26/2022
1.08
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SD-80”相匹配的价格&库存,您可以联系我们找货
