SD-50SN
SD-50SN
    CUIDEVICES
    CONN DIN 5 PIN FEMALE PANEL MNT
SD-50SN 数据手册
Additional Resources: Product Page | 3D Model date 09/26/2022 page 1 of 4 SERIES: SD-SN | DESCRIPTION: STANDARD DIN CONNECTOR FEATURES • panel mount • vertical • shielded RoHS PART NUMBER KEY SD - XX SN Base Number Note: *. Discontinued SD-30SN, SD-40SN & SD-50SN models. Pin Options 30* = 3 pins 40* = 4 pins 50* = 5 pins 60 = 6 pins 70 = 7 pins 80 = 8 pins SPECIFICATIONS parameter conditions/description min typ max 100 12 rated input voltage rated input current at 100 Vac at 12 Vdc contact resistance SD-40SN & SD-60SN all other models insulation resistance at 500 Vdc, SD-40SN at 500 Vdc, all other models voltage withstand for 1 minute insertion force SD-40SN all other models withdrawal force SD-40SN all other models life UL94V-0 RoHS yes 1 2 A A 20 30 mΩ mΩ MΩ MΩ 1,000 Vac 6.5 4 kg kg 1 1 5 3.5 kg kg 5 70 °C 5,000 flammability rating Vac Vdc 300 100 operating temperature cuidevices.com units cycles Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: SD-SN | DESCRIPTION: STANDARD DIN CONNECTOR date 09/26/2022 | page 2 of 4 MECHANICAL DRAWINGS units: mm tolerance: X.X ±0.38 mm X.XX ±0.25 mm X.XXX ±0.150 mm SD-30SN SD-50SN MATERIAL PLATING earth terminal phosphor bronze tin contact pins (SD-40SN) brass tin contact pins (all other models) brass silver socket case cold rolled steel nickel rivet aluminum nickel insulator PBT SD-70SN SD-40SN cuidevices.com SD-80SN Additional Resources: Product Page CUI DEVICES | SERIES: SD-SN | DESCRIPTION: STANDARD DIN CONNECTOR MECHANICAL DRAWINGS (CONTINUED) units: mm tolerance: X.X ±0.38 mm X.XX ±0.25 mm X.XXX ±0.150 mm SD-60SN cuidevices.com | 3D Model date 09/26/2022 | page 3 of 4 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: SD-SN | DESCRIPTION: STANDARD DIN CONNECTOR date 09/26/2022 | page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 02/23/2006 1.01 new template applied 02/10/2012 1.02 housing dimensions of SD-40SN changed 05/21/2014 1.03 housing dimensions of SD-60SN changed 09/01/2015 1.04 front face slots rotated on SD-40SN 10/26/2016 1.05 new tooling for housings 12/20/2016 1.06 brand update 02/19/2020 1.07 logo, datasheet style update 08/05/2022 discontinued models SD-30SN, SD-40SN & SD-50SN 09/26/2022 1.08 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SD-50SN 价格&库存
很抱歉,暂时无法提供与“SD-50SN”相匹配的价格&库存,您可以联系我们找货
