Additional Resources:
Product Page
3D Model
date
09/26/2022
page 1 of 4
SERIES: SD-SN | DESCRIPTION: STANDARD DIN CONNECTOR
FEATURES
• panel mount
• vertical
• shielded
RoHS
PART NUMBER KEY
SD - XX SN
Base Number
Note: *. Discontinued SD-30SN, SD-40SN & SD-50SN models.
Pin Options
30* = 3 pins
40* = 4 pins
50* = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
SPECIFICATIONS
parameter
conditions/description
min
typ
max
100
12
rated input voltage
rated input current
at 100 Vac
at 12 Vdc
contact resistance
SD-40SN & SD-60SN
all other models
insulation resistance
at 500 Vdc, SD-40SN
at 500 Vdc, all other models
voltage withstand
for 1 minute
insertion force
SD-40SN
all other models
withdrawal force
SD-40SN
all other models
life
UL94V-0
RoHS
yes
1
2
A
A
mΩ
mΩ
MΩ
MΩ
1,000
Vac
6.5
4
kg
kg
1
1
5
3.5
kg
kg
5
70
°C
5,000
flammability rating
Vac
Vdc
300
100
operating temperature
cuidevices.com
units
cycles
Product Page
3D Model
CUI DEVICES | SERIES: SD-SN | DESCRIPTION: STANDARD DIN CONNECTOR
date 09/26/2022 | page 2 of 4
MECHANICAL DRAWINGS
units: mm
tolerance:
X.X ±0.38 mm
X.XX ±0.25 mm
X.XXX ±0.150 mm
SD-30SN
SD-50SN
MATERIAL
PLATING
earth terminal
phosphor bronze
tin
contact pins (SD-40SN)
brass
tin
contact pins
(all other models)
brass
silver
socket case
cold rolled steel
nickel
rivet
aluminum
nickel
insulator
PBT
SD-70SN
SD-40SN
cuidevices.com
SD-80SN
Product Page
MECHANICAL DRAWINGS (CONTINUED)
units: mm
tolerance:
X.X ±0.38 mm
X.XX ±0.25 mm
X.XXX ±0.150 mm
SD-60SN
cuidevices.com
3D Model
date 09/26/2022 | page 3 of 4
Product Page
3D Model
date 09/26/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/10/2012
1.02
housing dimensions of SD-40SN changed
05/21/2014
1.03
housing dimensions of SD-60SN changed
09/01/2015
1.04
front face slots rotated on SD-40SN
10/26/2016
1.05
new tooling for housings
12/20/2016
1.06
brand update
02/19/2020
1.07
logo, datasheet style update
08/05/2022
discontinued models SD-30SN, SD-40SN & SD-50SN
09/26/2022
1.08
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SD-40SN”相匹配的价格&库存,您可以联系我们找货
