ECG.0B.304.CLN
www.lemo.com
SUMMARY
# Wires
Low voltage
4
Image is for illustrative purpose only
Series
0B
Termination type
Female print PCB
IP rating
50
AWG wire size
30.00 - 22.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.0B.304.CLAD56
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EC*: Fixed receptacle with two nuts and straight contacts for printed circuit (back panel
mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
5.10 g
Performance
Configuration
0B.304 : 4 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
7 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.7 mm (0.028in)
R (max): 6.1 mOhm
Vtest (contact-contact): 850 V (AC), 1200 V (DC)
Vtest (contact-shell): 700 V (AC), 990 V (DC)
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
Lmax
M
Nmax
S1
S3
e
mm.
12
12.4
5.5
19.55
2.5
16.3
8.2
11
M9x0.6
in.
0,47
0,49
0,22
0,77
0,10
0,64
0,32
0,43
RECOMMENDED BY LEMO
Tools
Spanner 2:
DCH.91.121.PA
Spanner wrench:
Socket for torque wrench DCM.65.100.AZ and DCM.0S.M09.4
2/3
3/3
很抱歉,暂时无法提供与“ECG.0B.304.CLN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+275.071941+35.58476
- 10+233.8170310+30.24781
- 30+216.3742630+27.99132
- 50+208.7178250+27.00084
- 100+198.76311100+25.71305
- 250+186.33249250+24.10496
- 500+177.45100500+22.95600
