ERA.1S.302.CLL
www.lemo.com
SUMMARY
# Wires
Low voltage
2
Image is for illustrative purpose only
Series
1S
Termination type
Female solder
IP rating
50
AWG wire size
28.00 - 20.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FFA.1S.302.CLAC32
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ERA*: Fixed receptacle, nut fixing
Keying
Hermaphroditic keying (half moon insert) with female pin 1
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
8.71 g
Performance
Configuration
1S.302 : 2 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
15 Amps
Specifications
Contact Type: Solder
Contact Dia.: 1.3 mm (0.051in)
Bucket Dia.: 1 mm (0.039in)
Max. Solid Conductor: 0.5 mm^2 (AWG 20)
Max. Stranded Conductor: 0.5 mm^2 (AWG 20)
R (max): 3.6 mOhm
Vtest: 1200 V (AC), 1800 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/4
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
S1
S3
e
mm.
14
16
7.5
21
1.5
10.5
14
M12x1.0
in.
0,55
0,63
0,30
0,83
0,06
0,41
0,55
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.1S.M12.4
2/4
Cables
CMN.02.T20.047PGZE
Grey
CMN.02.T20.047PNZE
CMN.02.T20.048QGZE
TPR (medical)
Grey
CMN.02.T28.030PGCE
PVC
GREY
CMN.02.T28.030PGZE
CMN.02.T28.030PNCE
Grey
PVC
Black
102080
PVC
Grey
120184
PVC
Black
120240
PVC
Black
120250
PVC
Grey
120500
PVC
Grey
120501
PVC
Grey
120751
PVC
Grey
20140
PVC
Grey
20140
PVC
Grey
20141
PVC
Grey
20142
PVC
Red
20143
PVC
Green
20144
PVC
Black
20145
PVC
Yellow
20146
PVC
Black
20240
PTFE
White
20260
PVC
Black
20264
PVC
Black
20266
PVC
Violet
2050
PVC
Black
20550
PUR
Black
20560
PUR
White
2080
PVC
Grey
220750
PVC
Grey
2221
PVC
Black
2260
PTFE
White
2280
PVC
Black
4082
PVC
Grey
CMN.02.T28.030PNZE
3/4
CMB.02.210.635
PUR
Black
4/4
很抱歉,暂时无法提供与“ERA.1S.302.CLL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+251.580671+32.58850
- 国内价格 香港价格
- 1+290.012521+37.20899
- 10+251.3442010+32.24779
- 25+221.7713025+28.45355
