21033814412
21033814412
    HARTING(浩亭)
    插件
21033814412 数据手册
Product data sheet 21 03 381 4412 M12 panel feed through PCB angled D-kod. M12 panel feed through PCB angled D-kod. Part number 21 03 381 4412 Specification M12 panel feed through PCB angled Dkod. HARTING eCatalogue https://b2b.harting.com/21033814412 Image is for illustration purposes only. Please refer to product description. Identification Category Connectors Series Circular connectors M12 Element PCB adapter Specification Angled for rear mounting Description of hood/housing With fixing hole Version Termination method Reflow soldering termination (THR) Gender Female Locking type Screw locking Shielding Shielded Number of contacts 4 Coding D-coding Details Coding bottom left = Cable entry direction on the angled connector: to the right Technical characteristics Rated current 4 A Rated voltage 50 V Rated impulse voltage 1.5 kV Pollution degree 3 Insulation resistance >108 Ω Contact resistance ≤10 mΩ Page 1 / 3 | Creation date 2020-03-31 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 381 4412 M12 panel feed through PCB angled D-kod. Technical characteristics Tightening torque 2 Nm Lock nut Ambient temperature -40 ... +85 °C Mating cycles ≥100 Degree of protection acc. to IEC 60529 IP20 Transmission characteristics Cat. 5 Class D up to 100 MHz Overvoltage category III Isolation group I (600 ≤ CTI) Material properties Material (insert) Liquid crystal polymer (LCP) Material (contacts) Copper alloy Surface (contacts) Gold plated Material (hood/housing) Zinc die-cast RoHS compliant with exemption RoHS exemptions 6(c): Copper alloy containing up to 4 % lead by weight ELV status compliant with exemption China RoHS 50 REACH Annex XVII substances No REACH ANNEX XIV substances No REACH SVHC substances Yes REACH SVHC substances Lead Specifications and approvals Specifications IEC 61076-2-101 UL / CSA UL 1977 ECBT2.E235076 CSA-C22.2 No. 182.3 ECBT8.E235076 PROFINET Yes Commercial data Packaging size 10 Net weight 19.36 g Country of origin Romania European customs tariff number 85366990 Page 2 / 3 | Creation date 2020-03-31 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 381 4412 M12 panel feed through PCB angled D-kod. Commercial data eCl@ss 27440402 PCB connector Page 3 / 3 | Creation date 2020-03-31 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
21033814412 价格&库存
很抱歉,暂时无法提供与“21033814412”相匹配的价格&库存,您可以联系我们找货
    • 10+169.40000
    • 20+168.85000
    • 40+168.57500
    • 80+168.44300
    库存:5000
    21033814412
    • 1+155.15280
    • 10+148.70520
    • 30+137.55960
    库存:17
    21033814412
    • 1+358.081541+46.12911
