FFA.0S.304.CLAC44
FFA.0S.304.CLAC44
    LEMO(雷莫)
    FFA.0S.304.CLAC44
FFA.0S.304.CLAC44 数据手册
FFA.0S.304.CLAC44 www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 0S Termination type Male solder IP rating 50 AWG wire size 32.00 - 24.00 Cable Ø 3.80 - 4.40 mm Status active Matching parts ERA.0S.304.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Hermaphroditic keying (half moon insert) with male pin 1 Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 7.75 g Performance Configuration 0S.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Max. Solid Conductor: 0.25 mm^2 (AWG 24) Max. Stranded Conductor: 0.14 mm^2 (AWG 26) R (max): 6.1 mOhm Vtest: 1060 V (AC), 1500 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 9 34.5 24.5 6.5 in. 0,35 1,36 0,96 0,26 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0S.ZZZ.PA065 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 40140 PVC Black 4280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.0S.304.CLAC44 价格&库存
很抱歉,暂时无法提供与“FFA.0S.304.CLAC44”相匹配的价格&库存,您可以联系我们找货
FFA.0S.304.CLAC44
  • 1+335.917811+43.60760
