FGG.1B.304.CLAD52Z
www.lemo.com
SUMMARY
# Wires
Low voltage
4
Image is for illustrative purpose only
Series
1B
Termination type
Male solder
IP rating
50
AWG wire size
30.00 - 22.00
Catalog
Cable Ø
4.30 - 5.20 mm
See video assembly instructions
Status
active
Matching parts
EGG.1B.304.CLL
Download
Request a quote
Eplan
PHG.1B.304.CLLD52Z
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet and nut for fitting a bend relief
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
12.18 g
Performance
Configuration
1B.304 : 4 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
10 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
R (max): 4.8 mOhm
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Vtest (contact-shell): 1450 V (AC), 2050 V (DC)
Vtest (contact-contact): 1350 V (AC), 1910 V (DC)
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S1
S2
mm.
12
42
31
10
9
in.
0,47
1,65
1,22
0,39
0,35
RECOMMENDED BY LEMO
Tools
2/3
Spanner wrench:
DCD.1B.ZZZ.PA090
Caps:
BFG.1B.100.PCSG
Cables
CMN.04.T22.047QGC
TPR
Grey
CMN.04.T22.048QGZE
TPR (medical)
Grey
140240
PVC
Black
140250
PVC
Grey
40260
PVC
Black
4080
PVC
Grey
4221
PVC
Black
4280
PVC
Black
80080
PVC
Grey
80082
PVC
Red
80084
PVC
Black
3/3
很抱歉,暂时无法提供与“FGG.1B.304.CLAD52Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+325.912191+41.90576
- 10+314.4752610+40.43520
- 25+293.8580425+37.78424
- 50+275.7724850+35.45880
- 100+259.78180100+33.40272
