FMN.2M.312.XLCT
FMN.2M.312.XLCT
    LEMO(雷莫)
    FMN.2M.312.XLCT
FMN.2M.312.XLCT 数据手册
FMN.2M.312.XLCT www.lemo.com SUMMARY # Wires Low voltage 12 Image is for illustrative purpose only Series 2M Termination type Male crimp IP rating 68 when mated AWG wire size 26.00 - 22.00 Cable Ø 6.50 - 13.00 mm Status active Matching parts PMN.2M.312.XLMT Download Request a quote Catalog See video assembly instructions TECHNICAL DETAILS Mechanics Shell Style/Model FM*: Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and mold stop Keying 3 keys (beta=165, gamma=30, plug: male contacts, receptacle: female contacts) Housing Material Aluminium (nickel plated [SAE AMS QQ N 290], anthracite color) shell and nut, other pieces bronze/brass Weight 10.03 g Performance Configuration 2M.312 : 12 Low Voltage Insulator L: PEEK Rated Current 7 Amps Specifications Contact Type: Crimp Contact Retention: 22 N Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Min. Conductor: 0.14 mm^2 (AWG 26) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Test voltage (kV rms) Contact-contact: 1.65 Test voltage (kV rms) Contact-shell: 1.15 Others Endurance (Shell): 3000 mating cycles Temp (min / max): -20°C / +200°C Humidity (max): 21 days at 95% Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter) Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz] Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz] Shock Resistance: 300 g [ 3 ms] Lighting strike EIA 364-75: 10K amps - 6 times Thermal shock: 5 cycles: -65°C to +150°C EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz) Salt Spray Corrosion: max. 48 hr DRAWINGS Dimensions A B C D F Lr Ls M P X mm. 17.6 14 17.2 13 15.5 27.5 27.5 10.1 3.9 7.1 in. 0,69 0,55 0,68 0,51 0,61 1,08 1,08 0,40 0,15 0,28 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools Crimp Tool: DPC.91.701.V Crimp settings: AWG/Selector = 22-24-26/6-5-5 Positionner: DCE.91.070.5MVC Extractor: DCF.93.070.4LT Replacement contact: FGN.0M.555.ZZC LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FMN.2M.312.XLCT
物料型号:FMN.2M.312.XLCT
器件简介:LEMO品牌的连接器,具有12根低压电线,适用于低电压应用。
引脚分配:2M.312型号具有12个接触点。
参数特性: - 接触类型:压接 - 接触保持力:22牛顿 - 接触直径:0.7毫米 - 桶直径:0.8毫米 - 最小导体截面积:0.14平方毫米(AWG 26) - 最大导体截面积:0.34平方毫米(AWG 22) - 最大电阻:6.1毫欧
功能详解: - 额定电流:7安培 - 绝缘体材料:PEEK - 测试电压:接触-接触1.65千伏rms,接触-壳体1.15千伏rms - 耐久性:3000次插拔循环 - 工作温度范围:-20°C至+200°C - 湿度:在95%湿度下21天 - 抗振性:包括枪击振动、正弦波振动和随机振动测试 - 抗冲击性:300g 3ms冲击测试 - 抗雷击:10KA 6次 - 热冲击:-65°C至+150°C 5个循环 - EMI屏蔽效能:1GHz时大于等于80dB,3GHz时大于等于70dB,6GHz时大于等于58dB,10GHz时大于等于40dB - 盐雾腐蚀:最多48小时
应用信息:适用于需要高可靠性和高性能的电子设备连接。
封装信息:直插式插头,带有滚花握把和模具定位,具有3个键位(beta=165, gamma=30),铝制(镍镀层),绝缘体材料为PEEK。
推荐工具: - 压接工具:DPC.91.701.V - 压接设置:AWG/选择器=22-24-26/6-5-5 - 定位器:DCE.91.070.5MVC - 提取器:DCF.93.070.4LT - 替换接触件:FGN.OM.555.ZZC
FMN.2M.312.XLCT 价格&库存
很抱歉,暂时无法提供与“FMN.2M.312.XLCT”相匹配的价格&库存,您可以联系我们找货
FMN.2M.312.XLCT
