EPG.1B.307.HLN
www.lemo.com
SUMMARY
# Wires
Low voltage
7
Image is for illustrative purpose only
Series
1B
Termination type
Female print PCB
IP rating
50
AWG wire size
30.00 - 22.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.1B.307.CLAD62Z
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EP*: Elbow receptacle for printed circuit (solder or screw fixing)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
PPS (Polyphenylene) shell, other pieces nickel plated [SAE AMS QQ N 290] brass
Weight
12.20 g
Performance
Configuration
1B.307/EPG : 7 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.7 mm (0.028in)
R (max): 6.1 mOhm
Test voltage contact-contact : 1.45 kV rms
Test voltage contact-body shell : 1.45 kV rms
Others
Endurance (Shell): 5000
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
D
H
I
K
L
N
R
mm.
11
16.6
7.5
14
13.3
27
12.6
7.62
in.
0,43
0,65
0,30
0,55
0,52
1,06
0,50
0,30
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“EPG.1B.307.HLN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+641.620581+83.34326
- 10+545.3844210+70.84267
- 30+504.7258130+65.56133
- 50+486.8773950+63.24291
- 100+463.66979100+60.22836
- 国内价格
- 1+340.88655
- 5+327.23401
- 25+324.34937
