FGG.2B.310.CLAD72Z
FGG.2B.310.CLAD72Z
    LEMO(雷莫)
    FGG.2B.310.CLAD72Z
FGG.2B.310.CLAD72Z 数据手册
FGG.2B.310.CLAD72Z www.lemo.com SUMMARY # Wires Low voltage 10 Image is for illustrative purpose only Series 2B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 6.30 - 7.20 mm See video assembly instructions Status active Matching parts EGG.2B.310.CLL Download Request a quote Eplan TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 29.23 g Performance Configuration 2B.310 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 8 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1300 V (AC), 1840 V (DC) Vtest (contact-contact): 1450 V (AC), 2050 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 15 49 37 13 12 in. 0,59 1,93 1,46 0,51 0,47 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.2B.ZZZ.PA120 Caps: BFG.2B.100.PCSG Cables CMN.10.T22.068QGZE TPR (medical) Grey 210240 PVC Black 210250 PVC Grey 210260 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.2B.310.CLAD72Z 价格&库存
很抱歉,暂时无法提供与“FGG.2B.310.CLAD72Z”相匹配的价格&库存,您可以联系我们找货
FGG.2B.310.CLAD72Z
  • 1+630.864701+81.94613
FGG.2B.310.CLAD72Z
    • 1+611.545831+78.68016
    • 10+590.0842510+75.91896
    • 25+551.3968325+70.94152
    • 50+517.4624850+66.57560
    库存:68
