FGG.2B.316.CLAD72Z
www.lemo.com
SUMMARY
# Wires
Low voltage
16
Image is for illustrative purpose only
Series
2B
Termination type
Male solder
IP rating
50
AWG wire size
30.00 - 22.00
Catalog
Cable Ø
6.30 - 7.20 mm
See video assembly instructions
Status
active
Matching parts
EGG.2B.316.CLL
Download
Request a quote
Eplan
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet and nut for fitting a bend relief
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
29.55 g
Performance
Configuration
2B.316 : 16 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
6 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
Max. Conductor: 0.34 mm^2 (AWG 22)
R (max): 6.1 mOhm
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Vtest (contact-shell): 1250 V (AC), 1770 V (DC)
Vtest (contact-contact): 950 V (AC), 1340 V (DC)
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S1
S2
mm.
15
49
37
13
12
in.
0,59
1,93
1,46
0,51
0,47
RECOMMENDED BY LEMO
Tools
2/3
Spanner wrench:
DCD.2B.ZZZ.PA120
Caps:
BFG.2B.100.PCSG
Cables
CMN.16.T28.070NNZZ
116280
PVC
Black
216260
PVC
Black
3/3
很抱歉,暂时无法提供与“FGG.2B.316.CLAD72Z”相匹配的价格&库存,您可以联系我们找货
