FGG.1B.307.CLAD52Z
FGG.1B.307.CLAD52Z
    LEMO(雷莫)
    FGG.1B.307.CLAD52Z
FGG.1B.307.CLAD52Z 数据手册
FGG.1B.307.CLAD52Z www.lemo.com SUMMARY # Wires Low voltage 7 Image is for illustrative purpose only Series 1B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.1B.307.CLL Download Request a quote Eplan PHG.1B.307.CLLD52Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 12.20 g Performance Configuration 1B.307 : 7 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1050 V (AC), 1490 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 12 42 31 10 9 in. 0,47 1,65 1,22 0,39 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.1B.ZZZ.PA090 Caps: BFG.1B.100.PCSG Cables CMN.07.T28.044PGZE Grey CMN.07.T28.044PNZE 70140 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1B.307.CLAD52Z 价格&库存
很抱歉,暂时无法提供与“FGG.1B.307.CLAD52Z”相匹配的价格&库存,您可以联系我们找货
FGG.1B.307.CLAD52Z
    • 1+381.340001+48.86232
    • 10+367.9639210+47.14840
    • 25+343.8334125+44.05648
    • 50+322.6735650+41.34520
    • 100+303.96490100+38.94800
    库存:135
    FGG.1B.307.CLAD52Z
    • 1+412.65284
    • 5+381.69705
    • 10+350.72940
    • 25+338.80508
    • 50+313.09362
    • 100+298.16745
    库存:8
    FGG.1B.307.CLAD52Z.
    • 1+412.65284
    • 5+410.05440
    • 10+407.45597
    • 25+404.85753
    • 50+402.25910
    • 100+399.66066
    库存:43
