SD-70
SD-70
    CUIDEVICES
    7 Position Circular Connector Plug, Male Pins Solder Nickel
SD-70 数据手册
Additional Resources: Product Page | 3D Model date 09/26/2022 page 1 of 5 SERIES: SD | DESCRIPTION: STANDARD DIN CONNECTOR FEATURES • strain relief • 3~13 pins • 100 Vac rated RoHS PART NUMBER KEY SD - XX Base Number Pin Options 30* = 3 pins 40* = 4 pins 50 = 5 pins, 180 degrees 60 = 6 pins 70 = 7 pins 80 = 8 pins, 270 degrees 81 = 8 pins, 262 degrees 130 = 13 pins Note: *. Discontinued SD-30 & SD-40 models. SPECIFICATIONS parameter conditions/description min rated input voltage rated input current typ max 100 12 at 100 Vac at 12 Vdc contact resistance insulation resistance at 500 Vdc voltage withstand for 1 minute Vac Vdc 1 2 A A 30 mΩ 100 MΩ insertion force 1,000 Vac 4 kg kg withdrawal force 1 3.5 operating temperature 5 70 life RoHS 5,000 yes cuidevices.com units °C cycles Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: SD | DESCRIPTION: STANDARD DIN CONNECTOR date 09/26/2022 | page 2 of 5 MECHANICAL DRAWINGS units: mm[inches] tolerance: ±0.1 mm 2.0 0.079 15.8 0.622 MATERIAL PLATING contact pins (30~80) brass nickel contact pins (81, 130) brass silver shell steel nickel insulator (30~80, 130) PBT insulator (81) ABS boot EVA 50.6 1.992 0.2 9.0 0.354 1.5 0.059 (TYP) 6.5 0.256 0.15 0.7 0.028 13.1 0.516 0.15 45° SD-30 SD-60 SD-40 SD-50 72° 90° SD-70 SD-80 0.7 60° 45° cuidevices.com 45° Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: SD | DESCRIPTION: STANDARD DIN CONNECTOR date 09/26/2022 | page 3 of 5 units: mm[inches] tolerance: ±0.1 mm SD-81 2.00 0.079 1.5 0.059 (8 PLCS) 6.5 0.256 0.3 59.0 2.323 1.0 8.3 0.327 16.0 0.630 0.3 41° 0.9 0.035 13.2 0.520 45° SD-130 15.9 0.63 13.2 0.52 0.78 0.03 0.02 (13 PLCS) 8.8 0.35 50.1 1.97 9.2 0.36 2.5 0.10 7.5 0.30 2.5 0.10 2.5 0.10 4.5 0.18 cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: SD | DESCRIPTION: STANDARD DIN CONNECTOR date 09/26/2022 | page 4 of 5 MECHANICAL ASSEMBLY cover 1 1 2 metal shield 2 PIN DETAILS 3 housing 3 Note: SD-130 has solid solder pins. All other models have solder cups. 2 STEP 1 solder wires to housing (3), assemble metal shield pieces (2) onto housing (3) STEP 2 slide cover (1) over metal shield (2) 2 3 2 2 cuidevices.com 1 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: SD | DESCRIPTION: STANDARD DIN CONNECTOR date 09/26/2022 | page 5 of 5 REVISION HISTORY rev. description date 1.0 initial release 02/23/2006 1.01 new template applied 02/15/2012 1.02 updated housings 04/12/2012 1.03 corrected center pin positioning on SD-80 09/13/2013 1.04 updated datasheet 05/22/2017 1.05 updated datasheet 10/16/2018 1.06 brand update 02/19/2020 1.07 logo, datasheet style update 08/05/2022 discontinued models SD-30 & SD-40 09/26/2022 1.08 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SD-70 价格&库存
很抱歉,暂时无法提供与“SD-70”相匹配的价格&库存,您可以联系我们找货
