Additional Resources:
Product Page
3D Model
date
02/19/2020
page
1 of 3
SERIES: SD-J │ DESCRIPTION: STANDARD DIN CONNECTOR
FEATURES
• plastic bushing
• strain relief
• 3~13 pin options
RoHS
PART NUMBER KEY
SD - XX J
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
81 = 8 pins
130 = 13 pins
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
max
100
rated input current
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
-5
yes
cuidevices.com
units
Vac
2
A
50
mΩ
100
operating temperature
RoHS
typ
MΩ
1,000
Vac
110
°C
Product Page
3D Model
CUI Devices │ SERIES: SD-J │ DESCRIPTION: STANDARD DIN CONNECTOR
date 02/19/2020 │ page 2 of 3
MECHANICAL DRAWINGS
units: mm[inches]
tolerance: ±0.1mm
35.5 1.398
11.8 0.465
MATERIAL
PLATING
pins
brass
silver
shell
steel
nickel
insulator (30~80, 130)
PC
insulator (81)
ABS
boot (30~80, 130)
EVA
boot (81)
PE
24.5 0.965
15.8 0.622
0.7 0.028
7
3
8
5
6
1
4
2
45°
6.5 0.256
SD-30J
3
SD-40J
4
1
1
3
2
SD-50J
3
2
SD-60J
5
1
5
4
4
3
7
3
5
0.7 0.028
6
1
4
7
3
5
SD-81J
0.9 0.035
6
1
7
3
8
5
4
2
2
45°
8
60°
45°
SD-80J
SD-70J
45°
cuidevices.com
SD-130J
41°
6
1
4
2
45°
2
6
2
72°
1
2
3
4
1
5
6
7
8
12
9
10
11
13
Product Page
3D Model
date 02/19/2020 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/22/2012
1.02
corrected center pin positioning on SD-80J and SD-81J
10/01/2013
1.03
updated datasheet
05/13/2015
1.04
updated datasheet
09/08/2017
1.05
updated datasheet
07/24/2018
1.06
brand update
02/19/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SD-130J”相匹配的价格&库存,您可以联系我们找货
