EGG.00.304.CLL
EGG.00.304.CLL
    LEMO(雷莫)
    EGG.00.304.CLL
EGG.00.304.CLL 数据手册
EGG.00.304.CLL www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 00 Termination type Female solder IP rating 50 AWG wire size 34.00 - 28.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.00.304.CLAD35Z Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 2.63 g Performance Configuration 00.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Bucket Dia.: 0.4 mm (0.016in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.05 mm^2 (AWG 30) R (max): 8.7 mOhm Vtest (contact-shell): 650 V (AC), 920 V (DC) Vtest (contact-contact): 800 V (AC), 1130 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 8 10.3 6 15.5 1 13.7 6.3 9 M7x0.5 in. 0,31 0,41 0,24 0,61 0,04 0,54 0,25 0,35 RECOMMENDED BY LEMO Tools Cables CMN.04.T28.031PGCE PVC CMN.04.T28.031PGZE CMN.04.T28.031PNCE GREY Grey PVC Black CMN.04.T28.031PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 CMN.04.T28.031QGC TPR Grey 40080 PVC Black 40086 PVC Blue 4041 PVC Grey 4050 PVC Black 4080 PVC Grey 417920 PVC Grey 4280 PVC Black 80080 PVC Grey 80082 PVC Red 80084 PVC Black CTR.75.030.121870G PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGG.00.304.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.00.304.CLL”相匹配的价格&库存,您可以联系我们找货
EGG.00.304.CLL
  • 1+248.327431+32.14340
  • 10+211.0852510+27.32279
  • 30+195.3418830+25.28497
  • 50+188.4280250+24.39005
  • 100+179.44145100+23.22683
  • 250+168.21932250+21.77424
  • 500+160.20146500+20.73641
库存:149
EGG.00.304.CLL
  • 1+146.97049
  • 5+144.03378
  • 25+139.70163
  • 50+135.02582
库存:43
EGG.00.304.CLL
    库存:3
