FFA.0S.302.CLAC42
FFA.0S.302.CLAC42
    LEMO(雷莫)
    CONN INLINE PLUG 2PIN SLD CUP
FFA.0S.302.CLAC42 数据手册
FFA.0S.302.CLAC42 www.lemo.com SUMMARY # Wires Low voltage 2 Image is for illustrative purpose only Series 0S Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 3.80 - 4.40 mm Status active Alternative part FFA.0S.302.CLAC44 Matching parts ERA.0S.302.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Hermaphroditic keying (half moon insert) with male pin 1 Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 7.82 g Performance Configuration 0S.302 : 2 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.0354in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest: 1500 V (AC), 2100 V (DC) Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 9 34.5 24.5 6.5 in. 0,35 1,36 0,96 0,26 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0S.ZZZ.PA065 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 120250 PVC Grey 20140 PVC Grey 20140 PVC Grey 20142 PVC Red 20143 PVC Green 20144 PVC Black 20145 PVC Yellow 20146 PVC Black 20260 PVC Black 20264 PVC Black 20266 PVC Violet 2280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.0S.302.CLAC42 价格&库存
很抱歉,暂时无法提供与“FFA.0S.302.CLAC42”相匹配的价格&库存,您可以联系我们找货
