FGG.0B.304.CLAD31Z
FGG.0B.304.CLAD31Z
    LEMO(雷莫)
    4 Position Circular Connector Plug, Male Pins Solder Cup Gold
FGG.0B.304.CLAD31Z 数据手册
FGG.0B.304.CLAD31Z www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 0B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 2.30 - 3.20 mm Status obsolete Alternative part FGG.0B.304.CLAD32Z Matching parts EGG.0B.304.CLL Download Request a quote Catalog See video assembly instructions TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 8.71 g Performance Configuration 0B.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-contact): 850 V (AC), 1200 V (DC) Vtest (contact-shell): 700 V (AC), 1000 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 9.5 35 25 8 7 in. 0,37 1,38 0,98 0,31 0,28 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.0B.ZZZ.PA070 Caps: BFG.0B.100.PCSG Cables CMN.04.T28.031PGCE PVC CMN.04.T28.031PGZE CMN.04.T28.031PNCE GREY Grey PVC Black CMN.04.T28.031QGC TPR Grey 4041 PVC Grey 4050 PVC Black CMN.04.T28.031PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0B.304.CLAD31Z 价格&库存
很抱歉,暂时无法提供与“FGG.0B.304.CLAD31Z”相匹配的价格&库存,您可以联系我们找货
