ECG.1B.308.CLN
www.lemo.com
SUMMARY
# Wires
Low voltage
8
Image is for illustrative purpose only
Series
1B
Termination type
Female print PCB
IP rating
50
AWG wire size
30.00 - 22.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.1B.308.CLAD52Z
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EC*: Fixed receptacle with two nuts and straight contacts for printed circuit (back panel
mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
10.65 g
Performance
Configuration
1B.308 : 8 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
5 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.7 mm (0.028in)
R (max): 6.1 mOhm
Vtest (contact-shell): 1150 V (AC), 1630 V (DC)
Vtest (contact-contact): 950 V (AC), 1340 V (DC)
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
Lmax
M
Nmax
S1
S3
e
mm.
16
15.8
6
22.9
3.5
19.5
10.5
14
M12x1.0
in.
0,63
0,62
0,24
0,90
0,14
0,77
0,41
0,55
RECOMMENDED BY LEMO
Tools
Spanner 2:
DCH.91.161.PA
Spanner wrench:
Socket for torque wrench DCM.1S.M12.4
2/3
3/3
很抱歉,暂时无法提供与“ECG.1B.308.CLN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+313.909481+40.38692
- 10+302.8907610+38.96927
- 25+283.0316525+36.41424
