FGG.0B.307.CLAD52Z
FGG.0B.307.CLAD52Z
    LEMO(雷莫)
    CONN INLINE PLUG 7PIN SLD CUP
FGG.0B.307.CLAD52Z 数据手册
FGG.0B.307.CLAD52Z www.lemo.com SUMMARY # Wires Low voltage 7 Image is for illustrative purpose only Series 0B Termination type Male solder IP rating 50 AWG wire size 34.00 - 28.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.0B.307.CLL Download Request a quote Eplan PHG.0B.307.CLLD52Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 8.62 g Performance Configuration 0B.307 : 7 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Bucket Dia.: 0.45 mm (0.018in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.09 mm^2 (AWG 28) R (max): 8.7 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 700 V (AC), 990 V (DC) Vtest (contact-contact): 800 V (AC), 1130 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 9.5 35 25 8 7 in. 0,37 1,38 0,98 0,31 0,28 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.0B.ZZZ.PA070 Caps: BFG.0B.100.PCSG Cables CMN.07.T28.044PGZE Grey CMN.07.T28.044PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0B.307.CLAD52Z
物料型号:FGG.0B.307.CLAD52Z
器件简介:LEMO公司生产的低电压电缆连接器,适用于7根线的应用。
引脚分配:7 Low Voltage,具体引脚分配未在文档中详细说明。
参数特性: - 额定电流:2.5安培 - 接触类型:焊接 - 接触直径:0.5毫米 - 桶直径:0.45毫米 - 最大固体导体:0.09平方毫米(AWG 28) - 最大绞合导体:0.09平方毫米(AWG 28) - 最大电阻:8.7毫欧 - 电压测试(接触-外壳):700伏交流,990伏直流 - 电压测试(接触-接触):800伏交流,1130伏直流
功能详解: - 端子:直插头,电缆固定螺母和用于安装弯曲缓解的螺母 - 键槽:1个键(alpha=0,插头:男性接触,插座:女性接触) - 外壳材料:黄铜(镀铬[SAE AMS 2460])外壳和固定螺母,镍镀[SAE AMS QQ N 290]黄铜锁紧套和中间件 - 变体:Z:用于安装弯曲缓解的螺母
应用信息:适用于需要低电压连接的应用,具体应用场景未在文档中详细说明。
封装信息: - 重量:8.62克 - 尺寸:长度9.5毫米,总长35毫米,中间部分25毫米,S1 8毫米,S2 7毫米 - 工作温度范围:-55°C至+250°C - 湿度:最大95%(在60°C/140°F时) - 振动:15g(10Hz至2000Hz) - 冲击抵抗力:100g(6ms) - 气候类别:50/175/21 - 屏蔽效能:最小75dB(10MHz),最小40dB(1GHz) - 盐雾腐蚀:>1000小时
推荐工具和配件: - 扳手:DCD.0B.ZZZ.PA070 - 帽:BFG.0B.100.PCSG - 电缆型号:CMN.07.T28.044PGZE(灰色)和CMN.07.T28.044PNZE
FGG.0B.307.CLAD52Z 价格&库存
很抱歉,暂时无法提供与“FGG.0B.307.CLAD52Z”相匹配的价格&库存,您可以联系我们找货
FGG.0B.307.CLAD52Z
    • 1+387.90963
    • 2+348.14669
    库存:46
    FGG.0B.307.CLAD52Z
      • 1+294.765081+36.09528
      • 10+284.4206610+34.82856
      • 25+265.7701225+32.54472
      • 50+249.4126850+30.54168
      库存:58
      FGG.0B.307.CLAD52Z
        • 1+370.23721
        库存:1
        FGG.0B.307.CLAD52Z
          • 1+521.792321+62.66700
          • 10+399.0607610+47.92700
          • 50+337.6949850+40.55700
          • 100+328.44432100+39.44600
          • 500+322.30774500+38.70900
          • 1000+319.193651000+38.33500
          • 2000+317.728202000+38.15900
          • 4000+316.812304000+38.04900
          库存:2
