FFR.1S.408.CLAE46
www.lemo.com
SUMMARY
# Wires
High voltage
1
Image is for illustrative purpose only
Series
1S
Termination type
Male solder High-Voltage
IP rating
50
AWG wire size
30.00 - 22.00
Cable Ø
4.00 - 4.60 mm
Status
active
Matching parts
ERA.1S.408.CLL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFR*: Straight plug for cable crimping with safety ring
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
13.56 g
Performance
Configuration
1S.408 : 1 High Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
6 Amps
Specifications
Contact Type: Solder
Test voltage (kV DC) 18
Test voltage (kV AC) 12.7
Rear of connector must be protected: ATUM
Creepage distance min.: 20.4 mm
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
L
mm.
12
53
in.
0,47
2,09
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.1S.ZZZ.PA085
2/3
3/3
很抱歉,暂时无法提供与“FFR.1S.408.CLAE46”相匹配的价格&库存,您可以联系我们找货
