EEG.1K.308.CLV
EEG.1K.308.CLV
    LEMO(雷莫)
    CONN PNL MNT RCPT 8SKT R/A PCB
EEG.1K.308.CLV 数据手册
EEG.1K.308.CLV www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 1K Termination type Female print 90° PCB IP rating 68 when mated AWG wire size 30.00 - 22.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FGG.1K.308.CLAC35 Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EE*: Fixed receptacle, nut fixing, with elbow contacts for printed circuit (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 20.68 g Performance Configuration 1K.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current Specifications Contact Type: Print (elbow) Contact Dia.: 0.7 mm (0.028in) R (max): 6.1 mOhm Vtest (contact-shell): 1150 V (AC), 1630 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E M N P S1 e mm. 20 20 6.2 3.5 24.3 10 14.5 M16x1.0 in. 0,79 0,79 0,24 0,14 0,96 0,39 0,57 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.1E.M16.6 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EEG.1K.308.CLV 价格&库存
很抱歉,暂时无法提供与“EEG.1K.308.CLV”相匹配的价格&库存,您可以联系我们找货
