EGN.2M.319.XLM
EGN.2M.319.XLM
    LEMO(雷莫)
    EGN.2M.319.XLM
EGN.2M.319.XLM 数据手册
EGN.2M.319.XLM www.lemo.com SUMMARY # Wires Low voltage 19 Image is for illustrative purpose only Series 2M Termination type Female crimp IP rating 68 when mated AWG wire size 26.00 - 22.00 Cable Ø 6.50 - 13.00 mm Status active Matching parts FMN.2M.319.XLC Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying 3 keys (beta=165, gamma=30, plug: male contacts, receptacle: female contacts) Housing Material Aluminium (nickel plated [SAE AMS QQ N 290], anthracite color) shell and nut, other pieces bronze/brass Weight 8.71 g Performance Configuration 2M.319 : 19 Low Voltage Insulator L: PEEK Rated Current 4 Amps Specifications Contact Type: Crimp Contact Retention: 22 N Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Min. Conductor: 0.14 mm^2 (AWG 26) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Test voltage (kV rms) Contact-contact: 1.2 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Test voltage (kV rms) Contact-shell: 0.95 Others Endurance (Shell): 3000 mating cycles Temp (min / max): -20°C / +200°C Humidity (max): 21 days at 95% Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter) Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz] Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz] Shock Resistance: 300 g [ 3 ms] Lighting strike EIA 364-75: 10K amps - 6 times Thermal shock: 5 cycles: -65°C to +150°C EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz) Salt Spray Corrosion: max. 48 hr DRAWINGS Dimensions C D E Ls Ls P S1 S2 e mm. 17.2 6.8 4.5 18.3 18.3 5.3 12.5 17 M14x1.0 in. 0,68 0,27 0,18 0,72 0,72 0,21 0,49 0,67 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools Crimp Tool: DPC.91.701.V Crimp settings: AWG/Selector = 22-24-26/6-5-5 Positionner: DCE.91.070.3MVM Extractor: DCF.93.070.4LT Replacement contact: EGN.0M.655.ZZM LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGN.2M.319.XLM 价格&库存
很抱歉,暂时无法提供与“EGN.2M.319.XLM”相匹配的价格&库存,您可以联系我们找货
EGN.2M.319.XLM
    库存:10
