ECG.1B.306.CLL
ECG.1B.306.CLL
    LEMO(雷莫)
    ECG.1B.306.CLL
ECG.1B.306.CLL 数据手册
ECG.1B.306.CLL www.lemo.com SUMMARY # Wires Low voltage 6 Image is for illustrative purpose only Series 1B Termination type Female solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.1B.306.CLAD42Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EC*: Fixed receptacle with two nuts (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 10.32 g Performance Configuration 1B.306 : 6 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1200 V (AC), 1700 V (DC) Vtest (contact-contact): 1050 V (AC), 1490 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 16 15.8 6 23 3.5 21.1 10.5 14 M12x1.0 in. 0,63 0,62 0,24 0,91 0,14 0,83 0,41 0,55 RECOMMENDED BY LEMO Tools Spanner 2: DCH.91.161.PA Spanner wrench: Socket for torque wrench DCM.1S.M12.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.06.T26.037QGZE TPR (medical) Grey CMN.06.T28.031PGCE PVC GREY CMN.06.T28.031PGZE CMN.06.T28.031PNCE Grey PVC Black CMN.06.T28.031PNZE CMN.06.T28.042QBCE TPR (medical) CMN.06.T28.044PGZE Grey CMN.06.T28.044PNZE 106220 PVC Black 106240 PTFE White 12080 PVC Grey 160140 PVC Grey 160240 PVC Black 160260 PVC Black 260250 PVC Grey 60260 PTFE White 6280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ECG.1B.306.CLL 价格&库存
很抱歉,暂时无法提供与“ECG.1B.306.CLL”相匹配的价格&库存,您可以联系我们找货
