SD-70LS
SD-70LS
    CUIDEVICES
    CONN DIN RECPT LOCKING PNL MT 7P
SD-70LS 数据手册
Additional Resources: Product Page | 3D Model date 07/02/2020 page 1 of 3 SERIES: SD-LS │ DESCRIPTION: STANDARD DIN CONNECTOR FEATURES • locking • panel mount • metal bushing RoHS PART NUMBER KEY SD - X X LS Base Number Pin Options 30 = 3 pins 40 = 4 pins 50 = 5 pins 60 = 6 pins 70 = 7 pins 80 = 8 pins SPECIFICATIONS parameter conditions/description min rated input voltage typ max 100 rated input current contact resistance insulation resistance at 500 Vdc voltage withstand for 1 minute life 5,000 UL94V-2 RoHS yes 2 A 20 mΩ MΩ -40 flammability rating Vac 100 operating temperature cuidevices.com units 1000 Vac 85 °C cycles Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: SD-LS │ DESCRIPTION: STANDARD DIN CONNECTOR date 07/02/2020 │ page 2 of 3 MECHANICAL DRAWINGS units: mm[inches] TOLERANCE: ±0.2mm MATERIAL PLATING contact terminals brass tin hex nut zinc nickel cover zinc nickel housing nylon 13.2 0.520 3.3 0.130 1.5 0.059 17.0 0.669 0.1 18.2 0.717 0.1 M18 2.0 0.079 (TYP) 20.0 0.787 M16 Panel Cutout SD-30LS SD-40LS SD-50LS 72° 45° 7.0 0.276 2 7.0 0.276 3 1 7.0 0.276 2 4 2 3 1 4 5 3 1 11.8 0.465 11.8 0.465 11.8 0.465 2.4 0.094 2.4 0.094 2.4 0.094 20.1 0.791 20.1 0.791 20.1 0.791 SD-60LS SD-70LS SD-80LS 20.1 0.791 20.1 0.791 60° 7.0 0.276 3 2 4 4 6 1 2 7.0 0.276 5 1 5 6 11.8 0.465 4 1 3 7 6 11.8 0.465 45° 2 7.0 0.276 5 8 3 7 0.70 0.028 45° 11.8 0.465 2.4 0.094 2.4 0.094 20.1 0.791 cuidevices.com 2.4 0.094 Additional Resources: Product Page CUI Devices │ SERIES: SD-LS │ DESCRIPTION: STANDARD DIN CONNECTOR | 3D Model date 07/02/2020 │ page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 02/23/2006 1.01 new template applied 01/27/2012 1.02 updated datasheet 11/24/2015 1.03 updated datasheet 09/08/2017 1.04 brand update 02/19/2020 1.05 updated datasheet 07/02/2020 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SD-70LS 价格&库存
很抱歉,暂时无法提供与“SD-70LS”相匹配的价格&库存,您可以联系我们找货
SD-70LS
  • 30+31.93234
  • 85+27.38612
  • 200+25.83848
  • 400+24.47219
库存:1055
