HEN.1M.308.XLNP
www.lemo.com
SUMMARY
# Wires
Low voltage
8
Image is for illustrative purpose only
Series
1M
Termination type
Female print PCB
IP rating
68 when mated
AWG wire size
30.00 - 22.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FMN.1M.308.XLC
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
HE*: Fixed receptacle, nut fixing for printed circuit, watertight
Keying
3 keys (beta=165, gamma=30, plug: male contacts, receptacle: female contacts)
Housing Material
Aluminium (nickel plated [SAE AMS QQ N 290], anthracite color) shell and nut, other pieces
bronze/brass
Variant
P : Watertight unmated
Weight
6.15 g
Performance
Configuration
1M.308 : 8 Low Voltage
Insulator
L: PEEK
Rated Current
5.0 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.7 mm (0.028in)
R (max): 6.1 mOhm
Test voltage (kV rms) Contact-contact: 1.3
Test voltage (kV rms) Contact-shell: 1.1
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 3000 mating cycles
Temp (min / max): -20°C / +80°C
Humidity (max): 21 days at 95%
Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter)
Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz]
Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz]
Shock Resistance: 300 g [ 3 ms]
Lighting strike EIA 364-75: 10K amps - 6 times
EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz)
Salt Spray Corrosion: max. 48 hr
DRAWINGS
Dimensions
A
C
E
H
Lr
Ls
N
P
R
S1
S2
e
mm.
18
17.8
5
7.62
21
20.8
16.8
5.3
13.8
12.5
16
M14x1.00
in.
0,71
0,70
0,20
0,30
0,83
0,82
0,66
0,21
0,54
0,49
0,63
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.65.160.AZ
2/3
3/3
很抱歉,暂时无法提供与“HEN.1M.308.XLNP”相匹配的价格&库存,您可以联系我们找货
