ECG.2B.310.CLN
ECG.2B.310.CLN
    LEMO(雷莫)
    ECG.2B.310.CLN
ECG.2B.310.CLN 数据手册
ECG.2B.310.CLN www.lemo.com SUMMARY # Wires Low voltage 10 Image is for illustrative purpose only Series 2B Termination type Female print PCB IP rating 50 AWG wire size 30.00 - 22.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FGG.2B.310.CLAD62Z Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EC*: Fixed receptacle with two nuts and straight contacts for printed circuit (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 17.29 g Performance Configuration 2B.310 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 8 Amps Specifications Contact Type: Print (straight) Contact Dia.: 0.9 mm (0.035in) R (max): 4.8 mOhm Vtest (contact-shell): 1300 V (AC), 1840 V (DC) Vtest (contact-contact): 1450 V (AC), 2050 V (DC) Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 20 19.2 6.5 24.8 3.5 21.5 13.5 17 M15x1.0 in. 0,79 0,76 0,26 0,98 0,14 0,85 0,53 0,67 RECOMMENDED BY LEMO Tools Spanner 2: DCH.91.201.PA Spanner wrench: Socket for torque wrench DCM.65.170.AZ and DCM.2S.M15.6 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ECG.2B.310.CLN 价格&库存
很抱歉,暂时无法提供与“ECG.2B.310.CLN”相匹配的价格&库存,您可以联系我们找货
ECG.2B.310.CLN
  • 1+606.258351+78.42878
  • 10+515.3067810+66.66280
  • 30+476.8885630+61.69282
  • 50+460.0230350+59.51101
  • 100+438.09578100+56.67438
库存:93
