PFG.2B.318.CYMD92
PFG.2B.318.CYMD92
    LEMO(雷莫)
    CONN PNL MNT RCPT 18SKT CRIMP
PFG.2B.318.CYMD92 数据手册
PFG.2B.318.CYMD92 www.lemo.com SUMMARY # Wires Low voltage 18 Image is for illustrative purpose only Series 2B Termination type Female crimp IP rating 50 AWG wire size 26.00 - 22.00 Cable Ø 8.30 - 9.20 mm Status active Matching parts FGG.2B.318.CYCD92 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PF*: Fixed receptacle, with two nuts, cable collet (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 32.06 g Performance Configuration 2B.318 : 18 Low Voltage Insulator Y: PEEK for crimp contacts Rated Current 5.5 Amps Specifications Contact Type: Crimp Contact Retention: 22 N Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Min. Conductor: 0.14 mm^2 (AWG 26) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 2100 V (AC), 2970 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-contact): 1450 V (AC), 2050 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M S1 S2 S3 e mm. 20 20 6.5 47 3.5 13.5 12 17 M15x1.0 in. 0,79 0,79 0,26 1,85 0,14 0,53 0,47 0,67 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Crimp Tool: DPC.91.701.V Crimp settings: AWG/Selector = 22-24-26/6-5-5 Positionner: DCE.91.072.BVM Extractor: DCC.07.04B.LAG Replacement contact: EGG.2B.655.ZZM Spanner wrench: Socket for torque wrench DCM.65.170.AZ and DCM.2S.M15.6 Cables 218220 PVC Black 218240 PVC Black 236080 PVC Grey 318250 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PFG.2B.318.CYMD92 价格&库存
很抱歉,暂时无法提供与“PFG.2B.318.CYMD92”相匹配的价格&库存,您可以联系我们找货
