FMW.3K.93C.TLMC96Z
FMW.3K.93C.TLMC96Z
    LEMO(雷莫)
    CONN BULKHEAD PLUG 2F2+4LV SKT
FMW.3K.93C.TLMC96Z 数据手册
FMW.3K.93C.TLMC96Z www.lemo.com SUMMARY # Wires Low voltage 2 High voltage 2 Fiber optic 2 Series 3K Termination type Hybrid contacts IP rating 50 AWG wire size 24.00 - 20.00 Cable Ø 8.90 - 9.50 mm Status active Matching parts PBW.3K.93C.TLCC96Z Image is for illustrative purpose only Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FM*: Fixed plug with round flange (4 hole fixing), cable adapter, with bend relief nut Keying 5 keys (alpha=95, beta=115, gamma=20, delta=30, plug: female LV, male HV, female FO contacts) Housing Material Stainless steel shell, collet nut and latch sleeve, nickel plated [SAE AMS QQ N 290] brass mid pieces Variant Z : Nut for fitting a bend relief Weight 154.47 g Performance Configuration 3K.93C : 2 FO Type F2, 2 HV + 2 LV Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Crimp Fiber Optic Contact: Type F2 Vtest power/signal (AC): 2250V , 1000V Working voltage power/signal(AC): 600V , 42V Cable type: SMPTE 311M or EBU R100 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 20000 mating cycles Temp (min / max): -40°C / +80°C Humidity (max):
FMW.3K.93C.TLMC96Z 价格&库存
很抱歉,暂时无法提供与“FMW.3K.93C.TLMC96Z”相匹配的价格&库存,您可以联系我们找货
FMW.3K.93C.TLMC96Z
