RNV14FTL510K
RNV14FTL510K
    SEI
    AXIAL-D2.4X6MM
    插件电阻 - 510KΩ ±1% 1/4W ±200ppm/℃
RNV14FTL510K 数据手册
RNV Series Stackpole Electronics, Inc. High Voltage Anti-moisture Metal Film Resistor Resistive Product Solutions Features: • • • • • • High voltage surge handling per IEC 60065.14.1, up to 7KV High tolerance to prolonged exposure to temperature and humidity stress Ideal for applications requiring high stability, reliability and voltage handling; including power inverters, AC adapters and switching power supplies 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Type / Code Power Rating (W) @ 70ºC Maximum Working Voltage (V)(1) 1600 (DC), 1150 (RMS) Note: (1) Lesser of √ P*R or maximum working voltage RNV14 0.25 Maximum Overload Voltage (V) TCR (ppm/ºC) 3200 (DC), 2300 (RMS) ± 100 ± 200 Ohmic Range (Ω) and Tolerance 1% and 5% 100K - 6.8M 100K - 15M Mechanical Specifications Type / Code L D d H Unit RNV14 0.236 ± 0.012 6.00 ± 0.30 0.094 ± 0.008 2.40 ± 0.20 0.022 ± 0.002 0.55 ± 0.05 1.102 ± 0.079 28.00 ± 2.00 inches mm Performance Characteristics Item Solvent Resistance Temperature Coefficient Resistance (TCR) Performance No serious scratches on the insulating surface Overload (short time) Resistance variation within ±(1% + 0.05 Ω) Voltage Proof Resistance variation within ±(0.5% + 0.05 Ω) Vibration Resistance variation within ±(0.5% + 0.05 Ω) Insulation Resistance 104MΩ or more Robustness of Terminations Resistance variation within ±(0.5% + 0.05 Ω) and no mechanical damage Resistance to Soldering Heat No mechanical and electrical deterioration Solderability More than 95% of the lead surface was covered by new solder after the leads were dipped in the solder ±100 ppm/ºC (100K - 6.8M) ±200 ppm/ºC (100K - 15M) Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 Test Method Resistor was dipped into solvent for 5 ± 0.5 minutes Measured resistance (R0 ohm) at room temperature (tºC) then measured again at 100ºC higher than room temperature ppm/ºC = (R - R0)/R0 X 106/{(T + 100) -t} Applied DC voltage 2.5 times rated voltage or max. overload voltage whichever is lower for 5 seconds ON, 45 seconds OFF. Repeated cycle 10 times. Maximum Overload voltage is not more than 2 x Max Working Voltage. Resistor was clamped in the through of a 90ºC metallic V-block and was tested at provided AC potential voltage for 1 minute. Test voltage: max overload voltage. Test voltage: 500V (AC) Applied 1.5 mm amplitude vibration to two directions, perpendicular to each other, for 6 hours each. Total 12 hours. Vibrating frequency is 10HZ - 2000HZ - 10HZ cycle in 20 minutes. Repeat cycle. Resistor was clamped in the through of a 90ºC metallic V-block at DC 100V for 1 minute. Tensile test: The body of the part is fixed. The tensile force was applied gradually up to 10 N. Twist test: Terminal lead was rotated 360º of the original axis of the bent terminal, alternating direction for 3 rotations. Resistance to wave soldering condition: Temperature/Time-Profile in accordance to the CECC00802. Max Temperature/Time: 260ºC, 10 seconds Dipped the lead into a solder bath (temperature 245ºC ± 5ºC) up to 4 ± 0.8 mm from the resistor body and held for 5 ± 0.5 seconds. www.seielect.com marketing@seielect.com RNV Series Stackpole Electronics, Inc. High Voltage Anti-moisture Metal Film Resistor Resistive Product Solutions Performance Characteristics (cont.) Item Performance Rapid Change of Temperature Resistance variation within ±(0.5% + 0.05Ω) Damp Heat Resistance variation within ±(1.5% + 0.05Ω) Endurance at 70ºC Resistance variation within ±(1.5% + 0.05Ω) Cold Resistance Resistance variation within ±(1.5% + 0.05Ω) Heat Resistance Resistance variation within ±(1.5% + 0.05Ω) Test Method Test: -55ºC for 30 minutes, 25ºC for 30 seconds, 155ºC for 30 minutes, 25ºC for 30 seconds. Resistance changed after continuous 5 cycles. Temperature 40ºC ± 2ºC, relative humidity 90 ~ 95%, inside bath for 1.5 hour and shut voltage 0.5 hour. Repeated cycle for 1,000 hours. Room temperature for 1 hour after test, then measured In constant temperature chamber 70ºC ± 2ºC, applied rated DC voltage for 1.5 hour and shut voltage for 0.5 hour. Cycle repeated for 1000 hours. Resistor was put into a bath at fixed temp of -55ºC ± 3ºC for 2 hours. After measured, left at room temp for 1 hour, then measured again. Resistor was put into a bath at fixed temp of 155ºC ± 3ºC for 16 hours. After measured, left at room temp for 1 hour, then measured again. In accordance with IEC60065.14.1, 50 discharges from a 1nF capacitor charged to Vmax; Figure 2. 12 discharges/minute 10 High Voltage Surge Test Vmax (kV) 9 Resistance variation within ±(1% + 0.05Ω) 8 7 6 5 4 0.01 0.1 1 Rx (MΩ) 10 100 Operating temperature range is -55ºC to +155ºC Power Derating Curve: Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RNV Series Stackpole Electronics, Inc. High Voltage Anti-moisture Metal Film Resistor Resistive Product Solutions Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RNV Series Stackpole Electronics, Inc. High Voltage Anti-moisture Metal Film Resistor Resistive Product Solutions Packaging Specifications A max. (1) 2.756 ± 0.118 70.00 ± 3.00 Type / Code RNV14 B max. 11.811 ± 0.197 300.00 ± 5.00 C 0.197 ± 0.020 5.00 ± 0.50 D (2) 2.047 ± 0.020 52.00 ± 0.50 Tape 0.250 6.35 Unit inches mm Dimension "E": This is a non-critical dimension that does not have a tolerance in the standard. Range of diameters is from 0.547" (13.9 mm) to 1.5" (38.1 mm) (1) Reference value only. The "A" dimension shall be governed by the overall length of the taped component. The distance between flanges shall be 0.59" (1.5 mm) to 0.315" (8 mm) greater than the overall component. (2) The given dimension "D" expresses the standard width spacing. A 26 mm narrow spacing is available as option "N" packaging code. RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series RNV Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) High Voltage Anti-Moisture Metal Film Resistor Axial YES 100% Matte Sn over Ni Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RNV Series Stackpole Electronics, Inc. High Voltage Anti-moisture Metal Film Resistor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 R N V 1 4 F T L 1 0 0 K Product Series Code Description High Voltage RNV Metal Film Power Rating Size W 14 0.25 Tolerance Code Tol F 1% J 5% Code A T Packaging Description Size Quantity Tape Box (52mm) 2000 14 Tape and Reel 5000 TCR Code ppm D 100 L 200 Resistance Value Four characters with the multiplier used as the decimal holder. 100 Kohm = 100K 1 Mohm = 1M00 15 Mohm = 15M0 Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com
RNV14FTL510K
物料型号:RNV系列
器件简介:Stackpole Electronics, Inc.生产的高压防湿金属膜电阻器,适用于需要高稳定性、可靠性和电压处理的应用,如电源逆变器、交流适配器和开关电源。
引脚分配:文档中未提供具体的引脚分配信息。
参数特性: - 工作电压:RNV14型号直流1600V,交流1150V - 最大过载电压:RNV14型号直流3200V,交流2300V - 功率额定:RNV14型号0.25W - 公差:1%和5% - 温度系数(TCR):100K至6.8M欧姆为±100ppm/°C,100K至15M欧姆为±200ppm/°C
功能详解: - 耐高压冲击:符合IEC 60065.14.1标准,最高可达7kV - 耐高温和湿度应力:适合长期暴露在温度和湿度环境下 - 100%符合RoHS标准,无铅 - 符合REACH标准 - 无卤素
应用信息:适用于电源逆变器、AC适配器和开关电源供应等要求高稳定性和可靠性的场合。
封装信息: - RNV14型号的尺寸数据以英寸和毫米为单位提供 - 提供卷带包装,具体尺寸和包装规格在文档中有详细描述
RNV14FTL510K 价格&库存
很抱歉,暂时无法提供与“RNV14FTL510K”相匹配的价格&库存,您可以联系我们找货
