MS24264R12T3PN
MS24264R12T3PN
    CINCH
    265003C3#16PINRECP
MS24264R12T3PN 数据手册
MIL-C-26500 C48 Series Introduction GENERAL DESCRIPTION The C48 Series describes a family of connectors qualified to MIL-C-26500. While maintaining the MIL-C-26500 mating interface, this product has also been expanded to include qualifications to numerous Boeing specifications to satisfy general purpose requirements and unique product challenges for shielding, environmental sealing, fluid resistance, and vibration. Design Features A. Positive Location Captivated Insert (Mechanical Interlock) B. Insert Face Seal C. Pin Contact, MIL-C-39029/31 D. Contact Pressuring Seal E. Anti-Deflection Disc F. Resilient Pin Insert G. Insert Rim Seal H. Dynamic “O” Ring Shell Seal I. Five-Key Shell Polarization J. Metal-to-Metal Shoulder K. Bayonet or Threaded Coupling, Permanent Captivation L. Contact Retention Clip M. Socket Contact, MIL-C-39029/32 N. Wire Sealing Risers O. Grommet The expanded Cinch C48 product family offers numerous product options qualified to Boeing high-performance requirements and product solutions developed for alternate termination styles/low-profile packaging. Product Description Cinch Series • Threaded non-decoupling design CN0966 • High-vibration bayonet plug with metal-to-metal bottoming shells C0909 CN1020 • Connectors for shell grounding / shielding effectiveness, non-rotating accessory teeth, and advanced fluid-resistance elastometers CN0966 CN0967 CN1020 CN1021 • Firewall Conformance CN0966 CN0967 • Low-profile connectors crimp - removable contacts CN0915 • Low-profile connectors fixed contacts / alternate termination styles CN0942 CN0944 3-2 Call Toll Free: 1 (800) 323-9612 C48 Series Cinch Numbers How to Order C48-0 6 R 22-55 P 6-102 Series Designation C48 -- Order Code (Deviations) 100 - Connector With Contacts & Cable Support 102 - Connector Less Cable Support With Contacts 105 - Connector Less Contacts With Cable Support 106 - Connector Less Contacts & Less Cable Support See order codes for Boeing on page 3-14 Coupling Style 0 -- Threaded 1 -- Bayonet Alternate Shell Positions 6, 7, 8, 9, 10 per table on page 3-4 (Omit for normal position) Shell Style 0 -- Square Flange Receptacle 3 -- Single-Hole Mounting Receptacle 6 -- Straight Plug Contact Style P -- Pin S -- Socket Environmental Class R -- Meets MIL-C-26500 (USAF) 3 Insert Arrangements (See page 3-4) Shell Size 8, 10, 12, 14, 16, 18, 20, 22, 24 Military Standard Part Numbers You can use MS* as well as C48 Series part numbers when ordering C48 Series connectors. *MS part numbers are supplied less cable support. If cable support is desired, it must be ordered separately. MS24266 R 22 T 55 P 6 Military Designation MS24264 -- Square-Flange Receptacle MS24265 -- Single-Hole Mounting Receptacle MS24266 -- Straight Plug Alternate Shell Positions N, 6, 7, 8, 9, Y per table on page 3-4 Contact Style P -- Pin S -- Socket Environmental Class R -- Meets MIL-C-26500 (USAF) Insert Arrangements (See page 3-4) Shell Size 8, 10, 12, 14, 16, 18, 20, 22, or 24 Coupling Style T -- Threaded B -- Bayonet Part numbers for the contacts and assembly tools are listed on page 3-12. Call Toll Free: 1 (800) 323-9612 3-3 Inserts Available C48 Series (Showing Front Face of Socket Inserts) Shell Size-12 Shell Size-10 Shell Size-8 (Y) (Y) (Y) (Y) (Y) Shell Size-16 Shell Size-14 (Y) (Y) (Y) Shell Size-18 (Y) 3 Shell Size-20 (Y) (Y) (Y) (Y) Shell Size-22 (Y) (Y) Shell Size-24 (Y) (Y) (Y) Shell Size-28 CN096X CN102X Series Only Alternate Shell Positions (Front face of receptacle shown) NOTE: Alternate positions 6 through Y incorporate special shell polarizing key and keyways. All inserts remain in the normal position. For Connector Size † = #1 shielded contact is interchangeable with #12 power contact. (Y) = Available in Boeing Insert Style. For Connector Size 8 and 10 12, 14, 16, 18, 20, 22, 24, and 28 Positions A B C D A B C D Normal (N) 105° 140° 215° 265° 105° 140° 215° 265° 6 102° 132° 248° 320° 18° 149° 192° 259° 7 80° 118° 230° 312° 92° 152° 222° 342° 8 35° 140° 205° 275° 84° 152° 204° 334° 9 64° 155° 234° 304° 24° 135° 199° 240° 10 or Y* 25° 115° 220° 270° 98° 152° 268° 338° *Not available in Size 8 Connector. See individual part number systems. 3-4 Call Toll Free: 1 (800) 323-9612 C48 Series Plug Connectors Threaded Coupling C48-06RXX-XXXX MS24266RXXTXXXX BACC45FS1 3 1.345 (34.164) Max. Bayonet Coupling C48-16RXX-XXXX MS24266RXXBXXXX BACC45FT1 1.345 (34.164) Max. Dimensions Shell Size 8 10 12 14 16 18 20 22 24 A. Dia. in mm .328 8.331 .420 10.668 .580 14.732 .664 16.866 .769 19.533 .902 22.911 1.033 26.238 1.152 29.261 1.282 32.253 B. Dia. in mm .437 11.100 .562 14.275 .750 19.050 .812 20.625 .938 23.825 1.062 26.975 1.182 30.023 1.312 33.325 1.432 36.373 C. Max. in mm .776 19.712 .906 23.013 1.078 27.381 1.141 28.982 1.266 32.157 1.375 34.925 1.510 38.354 1.625 41.275 1.760 44.704 D. Thread UNEF-2A .437-28 .562-24 .750-20 .812-20 .937-20 1.062-18 1.187-18 1.312-18 1.437-18 1 Boeing Specifications, see page 3-14. Call Toll Free: 1 (800) 323-9612 3-5 C48 Series Receptacle Connectors Square Flange, Threaded Coupling C48-OORXX-XXXX MS24264RXXTXXX BACC45FM1 1.407 (35.738) Max. Square Flange, Bayonet Coupling C48-1ORXX-XXXX MS24264RXXBXXX BACC45FN1 1.407 (35.738) Max. 3 Dimensions Shell Size 8 10 12 14 16 18 20 22 24 1 A +.005 (.127) in mm .812 20.625 .937 23.800 1.031 26.188 1.125 28.575 1.250 31.750 1.343 34.112 1.437 36.500 1.562 39.675 1.703 43.256 B +.005 (.127) in mm .594 15.088 .719 18.263 .812 20.625 .906 23.013 .969 24.613 1.062 26.975 1.156 29.363 1.250 31.750 1.375 34.925 C Max. Dia. in mm .125 3.175 .125 3.175 .125 3.175 .125 3.175 .125 3.175 .125 3.175 .125 3.175 .125 3.175 .154 3.912 D Max. in mm .561 14.250 .696 17.679 .875 22.225 .935 23.749 1.062 26.975 1.187 30.150 1.312 33.325 1.437 36.500 1.562 39.675 F Max. in mm .437 11.100 .562 14.275 .750 19.050 .812 20.625 .938 23.825 1.062 26.975 1.182 30.023 1.312 33.325 1.432 36.373 G H J Thread Thread Min. UNEF-2A UNEF-2A in mm .562-24 .437-28 .620 15.748 .687-24 .562-24 .748 18.999 .875-20 .750-20 .913 23.190 .937-20 .812-20 .980 24.892 1.062-18 .937-20 1.107 28.119 1.187-18 1.062-18 1.209 30.709 1.312-18 1.187-18 1.337 33.960 1.437-18 1.312-18 1.452 36.881 1.562-18 1.437-18 1.577 40.056 K Min. in .447 .572 .760 .822 .948 1.072 1.192 1.322 1.442 = Boeing specifications, see page 3-14. 3-6 Call Toll Free: 1 (800) 323-9612 mm 11.354 14.529 19.304 20.879 24.079 27.229 30.277 33.579 36.627 C48 Series Receptacle Connectors Single-Hole Mount, Threaded Coupling C48-03RXX-XXXX MS24265RXXTXXX 3 1.407 (35.738) Max. Single-Hole Mount, Bayonet Coupling C48-13RXX-XXXX MS24265RXXBXXX 1.407 (35.738) Max. Dimensions Shell Size A B C D E G H J K +.005 (.127) Max. Hex +.003 (.076) Max. Max. Dia. Max. Thread Thread Thread UNEF-2A UNEF-2A in mm in mm in mm in mm in mm in mm UNEF-2A 8 .979 24.867 .828 21.031 .593 15.062 1.068 27.127 .561 14.249 .437 11.100 .562-24 .625-20* .437-28 10 1.104 28.042 .953 24.206 .718 18.237 1.192 30.277 .696 17.678 .562 14.275 .687-24 .750-20 .562-24 12 1.291 32.791 1.140 28.956 .905 22.987 1.380 35.052 .875 22.225 .750 19.050 .875-20 .937-20 .750-20 14 1.391 35.331 1.250 31.750 .968 24.587 1.505 38.227 .935 23.749 .812 20.625 .937-20 1.000-20 .812-20 16 1.516 38.506 1.329 33.757 1.093 27.762 1.630 41.402 1.062 26.975 .938 23.825 1.062-18 1.125-20* .937-20 18 1.641 41.681 1.455 36.957 1.217 30.912 1.740 44.196 1.187 30.150 1.062 26.975 1.187-18 1.250-20* 1.062-18 20 1.766 44.856 1.642 41.707 1.342 34.087 1.860 47.244 1.312 33.325 1.182 30.023 1.312-18 1.375-18 1.187-18 22 1.954 49.632 1.705 43.307 1.467 37.262 2.040 51.816 1.437 36.500 1.312 33.325 1.437-18 1.500-20* 1.312-18 24 2.079 52.807 1.892 48.057 1.592 40.437 2.160 54.864 1.562 39.675 1.432 36.373 1.562-18 1.625-18 1.437-18 * Thread: UN-2A NOTES: Contact factory for information about Boeing specifications. For mounting hole dimensions and jam nut torques, see page 3-20. Call Toll Free: 1 (800) 323-9612 3-7 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cinch Connectivity Solutions: C48-06R14-7S9-106 C48-06R16-10P-102 C48-06R16-10P-106 C48-06R16-10P6-102 C48-06R16-10P6-106 C4806R16-10P7-102 C48-06R16-10P7-106 C48-06R16-10P8-102 C48-06R16-10P8-106 C48-06R16-10S-102 C4806R16-10S-106 C48-06R16-10S6-102 C48-06R16-10S6-106 C48-06R16-10S7-102 C48-06R16-10S7-106 C4806R16-10S8-102 C48-06R16-10S8-106 C48-06R16-24S-102 C48-06R16-24S-106 C48-06R16-24S6-102 C4806R16-24S6-106 C48-06R16-24S7-102 C48-06R16-24S7-106 C48-06R16-24S8-102 C48-06R16-24S8-106 C4806R18-14P-102 C48-06R18-14P-106 C48-06R18-14P6-102 C48-06R18-14P6-106 C48-06R18-14P7-102 C4806R18-14P7-106 C48-06R18-14P8-102 C48-06R18-14P8-106 C48-06R18-14P9-102 C48-06R18-14P9-106 C4806R18-14S-102 C48-06R18-14S-106 C48-06R18-14S6-102 C48-06R18-14S6-106 C48-06R18-14S7-102 C4806R18-14S7-106 C48-06R18-14S8-102 C48-06R18-14S8-106 C48-06R18-14S9-102 C48-06R18-14S9-106 C4806R18-31P-102 C48-06R18-31P-106 C48-06R18-31P6-102 C48-06R18-31P6-106 C48-06R18-31P7-102 C4806R18-31P7-106 C48-06R18-31P8-102 C48-06R18-31P8-106 C48-06R18-31P9-102 C48-06R18-31P9-106 C4806R18-31S-102 C48-06R18-31S-106 C48-06R18-31S6-102 C48-06R18-31S6-106 C48-06R18-31S7-102 C4806R18-31S7-106 C48-06R18-31S8-102 C48-06R18-31S8-106 C48-06R18-31S9-102 C48-06R18-31S9-106 C4806R18-8P-102 C48-06R18-8P-106 C48-06R18-8P6-102 C48-06R18-8P6-106 C48-06R18-8P7-102 C48-06R18-8P7106 C48-06R18-8P8-102 C48-06R18-8P8-106 C48-06R18-8P9-102 C48-06R18-8P9-106 C48-06R18-8S-102 C4806R18-8S-106 C48-06R18-8S6-102 C48-06R18-8S6-106 C48-06R18-8S7-102 C48-06R18-8S7-106 C48-06R188S8-102 C48-06R18-8S8-106 C48-06R18-8S9-102 C48-06R18-8S9-106 C48-06R22-12S-106 C48-10R10-20P6-102 C48-10R10-20P6-106 C48-10R10-20P7-102 C48-10R10-20P7-106 C48-10R10-20P8-102 C48-10R10-20P8-106 C48-10R10-20P9-102 C48-10R10-20P9-106 C48-10R10-5P6-102 C48-10R10-5P6-106 C48-10R10-5P7-102 C4810R10-5P7-106 C48-10R10-5P8-102 C48-10R10-5P8-106
MS24264R12T3PN 价格&库存
很抱歉,暂时无法提供与“MS24264R12T3PN”相匹配的价格&库存,您可以联系我们找货
