NRPN191PAEN-RC
NRPN191PAEN-RC
    SULLINS
    CONN HEADER 2MM SINGLE STR 19POS
NRPN191PAEN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY D 2024 9/17/2009 JH E 2673 HEAD HEIGHT 3.60MM WAS 4.00MM, UDATE WARP TOLERANCE UPDATE NOTE 4(WAS 1 AMP) 9/14/2012 LH F E E .079±.008 2.00±0.20 D D B±.020 [ .50] A±.008[ .20] .079±.002 2.00±0.05 .142±.008 3.60±0.20 C C .079 2.00 .110±.008 2.80±0.20 .020±.002 0.50±0.05 B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: GOLD FLASH OVERALL. 4. CURRENT RATING: 2 AMPS. 5. VOLTAGE RATING: 150V AC/DC. 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING: 500V AC. 9. OPERATING TEMPERATURE: -40° C TO +105° C. 10. *PROCESSING TEMP.: 260° C FOR 10 SECS MAX. 02-20, 0.20mm MAX. 21-30, 0.30mm MAX. 31-40, 0.40mm MAX. 7 6 B .079±.002 2.00±0.05 .031±.002 0.80±0.05 RECOMMENDED PCB LAYOUT Pb *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 A±.004 [ .10] UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 5 4 3 DATE NAME 12/17/08 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. HEADER MALE 2mm CC, 1 ROW, ST 5 DECIMALS X.X= .01 [0.3] .XX= .008 [.20] .XXX= .0060 [.15] RoHS COMPLIANT DRAWN NRPNxx1PAEN-RC SIZE DWG. NO. C REV 10531 SCALE: 16:1 2 E SHEET 1 OF 1 1 FILE NAME: Z:\ECO PENDING\2673, taiwan DWG update\10531, NRPNxx1PAEN-RC PRINT: 11/19/2012 A
NRPN191PAEN-RC 价格&库存
很抱歉,暂时无法提供与“NRPN191PAEN-RC”相匹配的价格&库存,您可以联系我们找货
