REVISION J
CC81X-XXXX-01-X
ALL DIMENSIONS ARE REFERENCE
(SEE C-281-XXXX-X FOR CONTROLLING PRINT)
DO NOT
SCALE FROM
THIS PRINT
0.38
SUPPLIED
-L: LOOSE
-R: REEL
PLATING SPECIFICATION
-L: 10μ" SELECTIVE GOLD IN CONTACT
AREA, MATTE TIN ON TAIL.
-S: 30μ" SELECTIVE GOLD IN CONTACT
LEAD STYLE
-2426: 24-26 AWG
-2830: 28-30 AWG
6.00
0.23
1.019 SQ
0.93
4.24
(2 PLCS)
13.27
14.86
"B"
10.21
"B"
0.58
(2 PLCS)
12.35
"A"
"A"
"P" MAX
(TAB LENGTH)
(SEE TABLE 2, SHT 2)
2.14
3.17
(CC81X-XXXX-01-X SHOWN)
1.270
3.000
"Q" MAX
(VESTIGE ALLOWANCE)
FIG 1
R"E"
6.00
R"G"
"D" REF
"B" REF
"F"
"A"
"C"
SECTION "B"-"B"
SCALE 16 : 1
NOTES:
1. PLATED C-281 PARTS TO BE PULLED, PLATING OPTION CONFIRMED, POSITIONED AS SHOWN
ON SAMTEC REEL WITH VIEWPORTS, LABELED CC81R WITH APPROPRIATE PLATING CALLOUT
AND LABEL PLACED AS SHOWN.
2. MAXIMUM No OF SPLICES PER REEL: 2.
3. SPLICES ARE NOT TO BE CONNECTED.
4. NUMBER OF SPLICES TO BE MARKED ON EACH REEL.
5. REELED PARTS TO BE INTERLEAVED WITH PAPER BETWEEN EACH LAYER OF PARTS.
6. ALLOWABLE INTERLEAF SPLICES PER REEL: 3.
7. SECURELY CONNECT INTERLEAF SPLICE.
8. OUTER WRAP SHALL RECEIVE PROTECTIVE REEL BAND PER BELOW: RB-24-0.75-P.
9. DUE TO PLATING REQUIREMENTS CONTACT SAMPLES MAY BE REMOVED INTERMITTINGLY
FROM THE CARRIER RESULTING IN SMALL GAPS BUT DOES NOT AFFECT FINAL COUNT.
10. QTY PER REEL: 17,000 +/-15 PCS.
11. MAXIMUM THREE SECTIONS OF MISSING PINS PER REEL. A SECTION IS DEFINED AS MINIMUM 0.5"
OR TWO PINS (WHICHEVER IS GREATER). SECTIONS GREATER THAN 3" WILL REQUIRE A SPLICE.
SECTION "A"-"A"
SCALE 16 : 1
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
MATERIAL:
ANGLES
DO NOT SCALE DRAWING
BeCu
THICKNESS: 0.127+/-0.008
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
SHEET SCALE: 8:1
c:\enterprisevault\DWG\MISC\MKTG\CC81X-XXXX-01-X-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
DWG. NO.
2mm C.L. DISCRETE WIRE CONTACT
CC81X-XXXX-01-X
BY: J. BORGELT
3/16/09
SHEET 1 OF 2
REVISION J
"K"
"H"
"J"
WIRE CRIMP
SCALE 20 : 1
INSULATOR STRIP LENGTH
FIG 2
RECOMMENDED PROCESSING
UNWINDING DIRECTION
"L"
"M"±3.18
(HUB)
12.7
LABEL UP
3.6
"N"±1.58
PROPRIETARY NOTE
CARRIER TO BE
ON LABEL SIDE
FIG 3
REEL SPECIFICATIONS
SHEET SCALE: 8:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
CC81X-XXXX-01-X
BY: J. BORGELT
3/16/09
SHEET 2 OF 2
很抱歉,暂时无法提供与“CC81L-2426-01-L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.908171+0.24798
- 250+1.77386250+0.23052
- 500+1.68802500+0.21937
- 1000+1.611731000+0.20945
- 5000+1.535435000+0.19954
- 10000+1.4591510000+0.18962
- 25000+1.4066925000+0.18281
