FGN.0M.555.ZZC
FGN.0M.555.ZZC
    LEMO(雷莫)
    FGN.0M.555.ZZC
FGN.0M.555.ZZC 数据手册
FGN.0M.555.ZZC www.lemo.com SUMMARY # Wires Low voltage 1 Image is for illustrative purpose only Series 0M Termination type Male crimp IP rating 68 when mated AWG wire size 26.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Male crimp contact for M series, standard barrel Keying No keying Housing Material Gold plated [ISO 27874] brass Weight .14 g Performance Configuration Insulator Rated Current Others Humidity (max): 21 days at 95% Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter) Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz] Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz] Shock Resistance: 300 g [ 3 ms] LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Lighting strike EIA 364-75: 10K amps - 6 times Thermal shock: 5 cycles: -65°C to +150°C EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz) DRAWINGS Dimensions A C mm. 0.7 0.87 in. 0,03 0,03 RECOMMENDED BY LEMO Tools Crimp Tool: DPC.91.701.V LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FGN.0M.555.ZZC 价格&库存
很抱歉,暂时无法提供与“FGN.0M.555.ZZC”相匹配的价格&库存,您可以联系我们找货
