FGN.0M.560.ZZC
www.lemo.com
SUMMARY
# Wires
Low voltage
1
Image is for illustrative purpose only
Series
0M
Termination type
Male crimp
IP rating
68 when mated
AWG wire size
24.00 - 20.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Male crimp contact for M series, standard barrel
Keying
No keying
Housing Material
Gold plated [ISO 27874] brass
Weight
.16 g
Performance
Configuration
Insulator
Rated Current
Others
Humidity (max): 21 days at 95%
Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter)
Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz]
Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz]
Shock Resistance: 300 g [ 3 ms]
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Lighting strike EIA 364-75: 10K amps - 6 times
Thermal shock: 5 cycles: -65°C to +150°C
EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz)
DRAWINGS
Dimensions
A
C
mm.
0.9
1.1
in.
0,04
0,04
RECOMMENDED BY LEMO
Tools
Crimp Tool:
DPC.91.701.V
2/2
很抱歉,暂时无法提供与“FGN.0M.560.ZZC”相匹配的价格&库存,您可以联系我们找货
