SWH.0E.304.CLLP
SWH.0E.304.CLLP
    LEMO(雷莫)
    CONNADAPT4P-4PF/M-F/MPNLMNT
SWH.0E.304.CLLP 数据手册
SWH.0E.304.CLLP www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 0E Termination type Coupler/adapter/bridge IP rating 68 when mated AWG wire size 32.00 - 24.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model SWH*: Fixed coupler, nut fixing, watertight or vacuum-tight Keying Hermaphroditic keying, pin 1 female on flange side, male on other side Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant P : Watertight unmated Weight 25.65 g Performance Configuration 0E.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.03in) Vtest: 1060 V (AC), 1500 V (DC) Others Endurance (Shell): 5000 mating cycles LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Temp (min / max): -20°C / +100°C Humidity (max): 1000 hr Pressure: 60 bars DRAWINGS Dimensions A B E L M S1 S3 e mm. 18 19.5 22.5 36 4 12.5 17 M14x1.0 in. 0,71 0,77 0,89 1,42 0,16 0,49 0,67 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
SWH.0E.304.CLLP 价格&库存
很抱歉,暂时无法提供与“SWH.0E.304.CLLP”相匹配的价格&库存,您可以联系我们找货
