RJG.2B.308.CLA
RJG.2B.308.CLA
    LEMO(雷莫)
    CONNADAPTER8P-8PF-MPNLMNT
RJG.2B.308.CLA 数据手册
RJG.2B.308.CLA www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 2B Termination type Coupler/adapter/bridge IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model RJ*: Fixed coupler, nut fixing, keys (J) at the flange end and keys (B or G) at the other end Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 36.71 g Performance Configuration 2B.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.04in) Vtest (contact-shell): 1250 V (AC), 1770 V (DC) Vtest (contact-contact): 1500 V (AC), 2120 V (DC) Others Endurance (Shell): 5000 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M S1 S3 e mm. 20 21.5 12 44 4 15 19 M16x1.00 in. 0,79 0,85 0,47 1,73 0,16 0,59 0,75 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
RJG.2B.308.CLA 价格&库存
很抱歉,暂时无法提供与“RJG.2B.308.CLA”相匹配的价格&库存,您可以联系我们找货
