SWH.2E.306.CLLP
www.lemo.com
SUMMARY
# Wires
Low voltage
6
Image is for illustrative purpose only
Series
2E
Termination type
Coupler/adapter/bridge
IP rating
68 when mated
AWG wire size
28.00 - 20.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
SWH*: Fixed coupler, nut fixing, watertight or vacuum-tight
Keying
Hermaphroditic keying, pin 1 female on flange side, male on other side
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
P : Watertight unmated
Weight
77.71 g
Performance
Configuration
2E.306 : 6 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
12 Amps
Specifications
Contact Type: Solder
Vtest: 1500 V (AC), 2100 V (DC)
Others
Endurance (Shell): 5000 mating cycles
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Temp (min / max): -20°C / +80°C
Humidity (max): 1000 hr
Pressure: 40 bars
DRAWINGS
Dimensions
A
B
E
L
M
S1
S3
e
mm.
25
27.5
28
52.4
5
18.5
24
M20x1.0
in.
0,98
1,08
1,10
2,06
0,20
0,73
0,94
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“SWH.2E.306.CLLP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1321.522651+170.82083
