SGJ.0B.307.CLLPV
SGJ.0B.307.CLLPV
    LEMO(雷莫)
    SGJ.0B.307.CLLPV
SGJ.0B.307.CLLPV 数据手册
SGJ.0B.307.CLLPV www.lemo.com SUMMARY # Wires Low voltage 7 Image is for illustrative purpose only Series 0B Termination type Coupler/adapter/bridge IP rating 68 when mated AWG wire size 34.00 - 28.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model SGJ*: Fixed coupler, nut fixing, keys (G, A, B, J, K, L) at the flange end and keys (G, A, B, J, K, L) at the other end, watertight or vacuum-tight Keying Front side: 1 key (alpha=0, female) ; Other side: 2 keys (gamma=45, male) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant PV : Watertight / Vacuum-tested unmated Weight 12.57 g Performance Configuration 0B.307 : 7 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Vtest (contact-shell): 700 V (AC), 990 V (DC) Vtest (contact-contact): 800 V (AC), 1130 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -20°C / +100°C Humidity (max): 1000 hr Pressure: 60 bars DRAWINGS Dimensions A B E L M S1 S3 e mm. 14 13.8 17 34 2 9 12 M10x0.75 in. 0,55 0,54 0,67 1,34 0,08 0,35 0,47 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
SGJ.0B.307.CLLPV 价格&库存
很抱歉,暂时无法提供与“SGJ.0B.307.CLLPV”相匹配的价格&库存,您可以联系我们找货
SGJ.0B.307.CLLPV
  • 10+1294.8080110+168.26361
