RGJ.3B.318.CLL
RGJ.3B.318.CLL
    LEMO(雷莫)
    CONN ADAPTER 18P-18P F-M PNL MNT
RGJ.3B.318.CLL 数据手册
RGJ.3B.318.CLL www.lemo.com SUMMARY # Wires Low voltage 18 Image is for illustrative purpose only Series 3B Termination type Coupler/adapter/bridge IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model RG*: Fixed coupler, nut fixing, key (G) at the flange end and keys (G,J or M) at the other end Keying 2 keys (alpha=37.5, plug: female contacts, receptacle: male contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 80.77 g Performance Configuration 3B.318 : 18 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.04in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest (contact-shell): 1050 V (AC), 1490 V (DC) Vtest (contact-contact): 1200 V (AC), 1700 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M S1 S3 e mm. 25 27.5 32 53 4 18.5 24 M20x1.00 in. 0,98 1,08 1,26 2,09 0,16 0,73 0,94 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
RGJ.3B.318.CLL
PDF文档中包含的物料型号为LEMO RGJ.3B.318.CLL。
器件简介为LEMO公司生产的3B系列连接器,具有18个低电压接触点。
引脚分配为3B.318,表示18个低电压接触点。
参数特性包括额定电流7安培,接触类型为焊接,接触直径0.9毫米,桶直径0.8毫米,最大固体导体面积0.34平方毫米(AWG 22),最大绞合导体面积0.34平方毫米(AWG 22),最大电阻4.8毫欧,接触-壳体电压测试1050伏交流电,1490伏直流电,接触-接触电压测试1200伏交流电,1700伏直流电。
功能详解包括外壳样式、型号、固定方式、材料、重量、性能配置、绝缘体材料、额定电流、接触规格、最大导体尺寸、电阻、电压测试等。
应用信息包括端子耐久性5000次,工作温度范围-55°C至+250°C,最大湿度95%(在60°C/140°F时),振动15g(10Hz至2000Hz),抗冲击100g(6ms),气候类别50/175/21,屏蔽效能最小75dB(10MHz)和40dB(1GHz),盐雾腐蚀超过1000小时。
封装信息包括尺寸参数,如A、B、E、L、M、S1、S3和螺纹尺寸M20x1.00。
RGJ.3B.318.CLL 价格&库存
很抱歉,暂时无法提供与“RGJ.3B.318.CLL”相匹配的价格&库存,您可以联系我们找货
RGJ.3B.318.CLL
  • 10+1883.3852610+243.64464
