RMA.4M.675.CTM
RMA.4M.675.CTM
    LEMO(雷莫)
    CONNADAPTER1P-1PM-MIN-LINE
RMA.4M.675.CTM 数据手册
RMA.4M.675.CTM www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 4M Termination type Female crimp triaxial IP rating 66 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model RMA*: Straight coupler Keying 1 key (alpha=0; plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 146.33 g Performance Configuration 4M.675 : 1 Triax (75 Ohm) Insulator T: PTFE Rated Current 15 Amps Specifications Vtest: 1500 V (AC), 2120 V (DC) Impedance: 75 Ohm Others Humidity (max): 1000 hr DRAWINGS Dimensions A L mm. 30 57 in. 1,18 2,24 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
RMA.4M.675.CTM 价格&库存
很抱歉,暂时无法提供与“RMA.4M.675.CTM”相匹配的价格&库存,您可以联系我们找货
