FTG.2K.308.CLF
FTG.2K.308.CLF
    LEMO(雷莫)
    FTG.2K.308.CLF
FTG.2K.308.CLF 数据手册
FTG.2K.308.CLF www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 2K Termination type Download Request a quote IP rating 68 when mated AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FT*: T-plug with receptacles (straight & elbow) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 115.14 g Performance Configuration 2K.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Dia.: 0.9 mm (0.035in) Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A B H L M mm. 16 19 48 77 60 in. 0,63 0,75 1,89 3,03 2,36 RECOMMENDED BY LEMO Tools Positionner: DCE.91.092.BVM Extractor: DCC.09.05B.LAG LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FTG.2K.308.CLF 价格&库存
很抱歉,暂时无法提供与“FTG.2K.308.CLF”相匹配的价格&库存,您可以联系我们找货
