TSM-104-02-L-SV-P-TR 数据手册
TSM-1XX-XX-XXX-SV-XX-XXX-XX
REVISION BX
C
(No OF POS x .100[2.54])
LEAD STYLE
SEE TABLE 1
PLATING SPECIFICATION
-T: MATT TIN CONTACT AND TAIL
-S: SELECTIVE, 30 Au / 50 Ni MIN ON
CONTACT, MATTE TIN TAIL
OPTION #2
-G: GOLD, 10 Au / 50 Ni MIN ON CONTACT,
POLARIZED POSITION: SPECIFY PIN OMITTED
3 Au / 50 Ni MIN ON TAIL
-L: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON
OPTION #1
CONTACT, MATTE TIN ON TAIL
-LC: LOCKING CLIP (SEE FIG. 1)(SEE NOTE 8)
-F: FLASH SELECTIVE, 3 Au / 50 Ni MIN ON
[USE LC-08-TM-02](-03 THRU -36 POS: 2 PER STRIP,
-02 POS: 1 PER STRIP)
-H: HEAVY GOLD, 30 Au / 50 Ni MIN ON
-A: ALIGNMENT PIN (SEE FIG. 2)
CONTACT, 3 Au / 50 Ni MIN ON TAIL
-TL: TIN / LEAD (90/10+/-5%) CONTACT AND TAIL
ROW SPECIFICATION
[LEAD STYLE -01 & -02 ONLY]
-STL: SELECTIVE, 30 Au / 50 Ni MIN ON
-SV: SINGLE VERTICAL (USE TSM-XX-SV-XX)
CONTACT, TIN/LEAD (90/10+/-5%) TAIL
-TM: MATTE TIN CONTACT AND TAIL
-SM: SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL
-LM: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL
-FM: FLASH SELECTIVE, 3 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL
-SS: STRIPE SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL (SEE NOTE 9)
.000[.00]
.015[.38]
(No OF POS -1) x .100[2.54]
02
.100 2.54 REF
01
5 MAX SWAY
(TYP)
TSM-XX-SV
T-1S6-XX-X-2
2 MAX SWAY
(EITHER DIRECTION)
2 MAX TOE
(TYP)
.025 0.64 SQ
REF(TYP)
C
"F"
(CONTACT AREA)
"B" .008[.20]
(SEE TABLE 1
& NOTE 5)
.100 2.54 REF
C
+5°
90° - 0°
(TYP)
C
(No OF POS -2) x .100[2.54]
"B"
LC-08-TM-02
.010 0.25 REF
C
2 MAX SWAY
(EITHER DIRECTION)
IN-PROCESS
.050±.010 1.27±0.25
(TYP)
.006
.099 2.51
NOTES:
OPTION #3
-P: PICK & PLACE PAD (SEE FIG. 3)
[USE PPP-07](4 POS MINIMUM
OR -02 & -03 POS WITH -TR & -FR)
(SEE NOTE 7)
-TR: TAPE & REEL (SEE NOTE 7 & 12)
(-02 THRU -22 POS)
-FR: FULL REEL QTY. TAPE & REEL
(-02 THRU -22 POS) (SEE NOTE 7 & 11)
No OF POSITIONS
-02 THRU -50
DO NOT
SCALE FROM
THIS PRINT
C
.002[.05]
.005[.13]
(SEE TABLE 1
& NOTE 5)
"D" MAX
"E" REF
.056 1.42 REF
1. C REPRESENTS A CRITICAL DIMENSION.
FIG 1
2. COPLANARITY TO BE WITHIN .006[.15].
TSM-112-02-XXX-SV-LC SHOWN
3. BURR ALLOWANCE: .0015[.038] MAX.
4. MAXIMUM CUT FLASH: .015[.38] MAXIMUM ON TOP & SIDES OF BODY
UNLESS OTHERWISE SPECIFIED,
AND .030[.76] MAXIMUM ON SURFACE MOUNT SIDE OF BODY.
DIMENSIONS ARE IN INCHES.
5. POST HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[.13] MAXIMUM.
TOLERANCES ARE:
6. MAXIMUM ALLOWABLE BOW: .002[.05] INCH/INCH AFTER ASSEMBLY.
DECIMALS
ANGLES
7. LEADS MAY NOT BE VISIBLE FOR CUSTOMER VISUAL INSPECTION WITH -P
.XX: .01 [.3]
2
OPTION ON SMALLER POSITIONS PARTS.
.XXX: .005 [.13]
8. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION
.XXXX: .0020 [.051]
IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS
MATERIAL:
DO NOT SCALE
MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE –LC OPTION.
INSULATOR:
9. -01 LEAD STYLE ONLY, MATES WITH SSW, SSQ, BCS, SSM, ESW, ESQ.
LCP,
UL
94
VO
10. MINIMUM PUSHOUT FORCE: 2LB. [8.90 N].
COLOR: BLACK
11. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED.
12. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING
TERMINAL: PHOS BRONZE
TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM.
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DRAWING
SHEET SCALE: 2.5:1
F:\DWG\MISC\MKTG\TSM-1XX-XX-XXX-SV-XX-XXX-XX-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
SINGLE ROW .100 SMT ASSEMBLY
DWG. NO.
BY: DEAN P
8/21/2002
SHEET 1 OF 2
REVISION BX
FIG 3
FIG 4
-P: PICK & PLACE PAD OPTION
4 POSITION MINIMUM
[PLACE PAD ON CENTERLINE AS SHOWN]
TUBE PACKAGING
.400 10.16
REF
"A"
(SEE TABLE 3)
CL
PPP-07
.270 6.86
REF
"C" .010[.25]
NOTES:
1. LOAD PARTS POSITION 1 FIRST IN SAME DIRECTION AS ARROW.
2. NOTE DELETED
3. PACKAGE POSITIONS -04 THRU -36.
4. POLARIZED 4 POSITION PARTS WITHOUT PADS ARE TO BE LAYER PACKAGED
OR PACKAGED IN TAPE AND REEL.
FIG 5
-TR: TAPE & REEL PACKAGNG OPTION
POS 1 (TOWARD
ROUND HOLE)
"A" = (No OF POSITIONS x .100[2.54]) - .400[10.16]
2
FIG 2
-A: ALIGNMENT PIN OPTION
TSM-112-02-X-SV-A SHOWN
[DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1]
USER DIRECTION OF UN-REELING
POCKET NOT DETAILED
SEE TABLE 2
.100 2.54 REF
(No OF POS -2) x .100[2.54] REF
.062 1.57
REF
PROPRIETARY NOTE
DO NOT SCALE DRAWING
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: DEAN P
8/21/2002
SHEET 2 OF 2
