ERA.3S.314.CLL
www.lemo.com
SUMMARY
# Wires
Low voltage
14
Image is for illustrative purpose only
Series
3S
Termination type
Female solder
IP rating
50
AWG wire size
30.00 - 22.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FFA.3S.314.CLAC10
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ERA*: Fixed receptacle, nut fixing
Keying
Hermaphroditic keying (half moon insert) with female pin 1
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
25.86 g
Performance
Configuration
3S.314 : 14 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
7 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.9 mm (0.0354in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
R (max): 4.8 mOhm
Vtest: 1500 V (AC), 2100 V (DC)
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
S1
S3
e
mm.
22
25.1
11.5
29
2
16.5
22
M18x1.0
in.
0,87
0,99
0,45
1,14
0,08
0,65
0,87
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.65.200.AZ
2/3
Cables
CMN.14.T22.068PGCE
PVC
CMN.14.T22.068PGZE
CMN.14.T22.068PNCE
GREY
Grey
PVC
Black
CMN.14.T22.068PNZE
CMN.14.T28.056PGZE
Grey
CMN.14.T28.056PNZE
CMN.14.T28.056QGZE
TPR (medical)
Grey
114260
PTFE
White
214140
PVC
Black
214240
PTFE
White
314250
PVC
Grey
3/3
很抱歉,暂时无法提供与“ERA.3S.314.CLL”相匹配的价格&库存,您可以联系我们找货
