HR41A-17WBR-C
HR41A-17WBR-C
    HRS(广濑)
    CONNCAPFORHR41ARCPTSIZE17
HR41A-17WBR-C 数据手册
MKT-E-13026F_0.3 HR41A Series IP68 Small Plastic Power Connector Optimized Optimized for for Outdoor Outdoor Use Use  Features 1. IP68* weather-resistant waterproof connector for outdoor use 2. Higher lightning surge protection (15 kV) and withstanding voltage 3. Snap-in mating with user-friendly push-on bayonet lock 4. Bayonet assembly eliminates torque management and re-tightening of screw *Our test condition: No water intrusion, while submerged in 2 m 5. Easy field assembly water depth for 14 days in mated condition. 6. UL, TÜV pending  Small Size Component - Plug (HR41A-17WBP-5SC)  16.8  24.6 65.8 Cable Size:  10.7 to 11.5  9.0 to 9.8 (Under development)  8.2 to 9.0 (Under development) - Receptacle (HR41A-17WBRA-5PC)  21.0  19.8 41.2 - Jack (HR41A-17WBJ-5PC)  21.0 74 Cable Size: Same as plug - Crimping Tool Part No.: HT802/HR41A-11-16(AWG#16) HT802/HR41A-11-18(AWG#18) HT802/HR41A-11-20(AWG#20) Finish / Remarks Material Housing PBT UL94V-0, Black Contact Phosphor Bronze Gold Plating Clamp Polyamide Resin UL94V-0, White O-ring, Gasket Silicone Rubber - Washer Stainless Steel - Rated Voltage AC 250V, DC 350V Rated Current 10 Amps Operating Temperature -40℃ to +105℃ Contact Resistance 5mΩ Max. (1A) Insulation Resistance 5000MΩMin. (DC500V) Withstanding Voltage AC 2200V, 1 minute Durability 500 times Water Resistance IP68 (Our test condition: No water intrusion, while submerged in 2 m water depth for 14 days in mated condition.) - Contact Extraction Tool Part No.: HR41A-TP Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities. © 2014 HIROSE ELECTRIC CO., LTD. All rights reserved. Issued: Sep. 12, 2014
HR41A-17WBR-C 价格&库存
很抱歉,暂时无法提供与“HR41A-17WBR-C”相匹配的价格&库存,您可以联系我们找货
