NREC034SABC-M30RC
NREC034SABC-M30RC
    SULLINS
    CONN HEADER .100" SNGL SMD 34POS
NREC034SABC-M30RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO C 2668 D 2828 F E DESCRIPTION DATE ADD 'LCP' MATERIAL AND REMOVE 'NYLON 9T' 09/06/2012 UPDATE PROCESSING TEMPERATURE FOR NYLON 6T MATERIAL, ADD 2-POSITION DIMENSION ON TABLE, 04/09/2015 UPDATE LCP OPERATING TEMP TO -40 C TO +125 C (WAS -40 C TO +105 C) BY LH LH F B 0.012[ 0.30] PIN 1 E .100 2.54 _R_C_ _ _S_ _C-M30RC (STANDARD) A B 0.012[ 0.30] PIN 1 .039 1.00 D D .100 2.54 PIN 1 C DIM. _R_C_ _ _S_ _D-M30RC (OPPOSITE BEND, ONLY APPLICABLE ON EVEN PIN COUNTS) .100 2.54 .200 5.08 RECOMMEND PCB LAYOUT _R_C_ _ _S_ _C-M30RC (STANDARD) A C C A .100 2.54 .200 5.08 HEAD DIM. C DIM. .004 [0.10] B .098 2.50 .100 2.54 .025 0.64 A PIN 1 .160 4.06 7 B RECOMMEND PCB LAYOUT TAIL DIM .010[0.25] _R_C_ _ _S_ _D-M30RC (OPPOSITE BEND) NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, BLACK. 2. CONTACT MATERIAL: SEE PART NUMBER CODING. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 3 AMPS. 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: 1000 VAC. 8. OPERATING TEMPERATURE: SEE PART NUMBER CODING. 8 .039 1.00 6 Pb RoHS COMPLIANT 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: .XX= .01 [.3] .XXX= .008 [.20] .XXXX= .0040 [.100] DRAWN DATE NAME 03/22/2011 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER MALE .100"[2.54mm]PITCH, SMT PART NUMBER SIZE C 54453 SCALE: 4:1 3 2 _ R _C_ _ _S_ _ _-M30RC CAGE CODE DWG. NO. 11657 SHEET 1 OF 1 1 REV D FILE NAME: 11657, _R_C_ _ _S_ _ _-M30RC A
NREC034SABC-M30RC 价格&库存
很抱歉,暂时无法提供与“NREC034SABC-M30RC”相匹配的价格&库存,您可以联系我们找货
