GMA.0B.030.DG
GMA.0B.030.DG
    LEMO(雷莫)
    GMA.0B.030.DG
GMA.0B.030.DG 数据手册
GMA.0B.030.DG www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 0B Termination type No contacts / Accessory IP rating 0 AWG wire size 0.00 - 0.00 Cable Ø 3.00 - 3.40 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model GMA*: Bend relief Grey Keying No keying Housing Material Brass (gold plated [ISO 27874]) shell, collet nut, brass latch sleeve and mid pieces Variant G : Gray Weight .42 g Performance Configuration Insulator G: PEEK/Pehd Rated Current Others Temp (min / max): -40°C / +80°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A L mm. 3.0 24 in. 0,12 0,94 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
GMA.0B.030.DG 价格&库存
很抱歉,暂时无法提供与“GMA.0B.030.DG”相匹配的价格&库存,您可以联系我们找货
GMA.0B.030.DG
    • 1+47.596171+6.18250
    • 10+40.4247510+5.25097
    • 30+37.4073530+4.85903
    • 50+36.0828850+4.68699
    • 100+34.35923100+4.46309
    • 250+32.20793250+4.18365
    • 500+30.67125500+3.98404
    • 1000+29.208301000+3.79401
    • 2500+27.381702500+3.55675
    库存:27
